I have 3 breezes and all have stopped running...like there is no power any longer...I have replaced filters and triied switching plug in cords between the 3 but over the course of 3 years all 3 have stopped running. Any ideas what I can check next or do I need to ship them all in to get repaired?
At the rear of the unit is the filter. When the filter is removed, the small screw or whatever it is called, that is attached to the filter on the lower right side, disengages the the safety switch just below the filter on the unit itself, if there is nothing to hold down this safety switch the unit will not operate. So take off the filter, there is a small notch on the unit, inside this notch is the safety switch, Try pressing down on this switch and see what happens. I hope this helps. Also, it may be the fuse.
i just dusted my unit and it won't start up again,did all of the above still nothing.
Again unit just stopped working. Seems like the buttons on front panel have been getting progressively more finicky over time too.
Have you regularly oiled the fan motors?
