Question about KitchenAid KUDR24SE Built-in Dishwasher
Kitchenaid KUDR24SEWH1 Does Everything but Wash.
Opened the door because the dishwasher wasn't washing and there was a plastic measuring cup at the bottom melted from the heating element. I took all the dishes out turned the breaker off for a while then tried again. Doesn't matter which cycle its in it does the same thing. Press start... begins to fill with water... then silence. If it sits long enough eventually it will simply switch over to the green light that says the dishes are clean. When you open it up there is the water that it had filled initially. I can press and hold the Cancel button and it will syphon the water out but thats it.
Thank you for any help.
  • 878 Answers
SOURCE: cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out back.
Posted on Oct 15, 2006
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
  • 423 Answers
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
Good Luck!
Posted on Apr 10, 2009
  • 423 Answers
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
Posted on Apr 11, 2009
  • 12 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
The problem is the control panel. You may have to shut the power off for a few seconds to reset the control board, then check to see if it works. If not, the control board has a break in the wiring or the keypad is no good.
Posted on May 13, 2009
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
check to make sure that there is enough water in the dishwasher. if not then take a container and pour some water inside, place a cup right side up in the top rack. close door and and set the machine to wash. wait about 30 seconds, then open the door, if the cup is half full or better, then your pump is good. and your problem is with your water inlet valve. the mesh probably needs cleaning, better yet just replace it.
Feb 03, 2011 | Dishwashers
I have Kitchenaid dishwasher KUDL03, Having trouble with white film on everything. stainless steel pots and pans has white film on them. stop using the rinse aid. use powder and watch the amount we put in....
You need to do a vinegar wash, the film you are getting is from a change in detergent. many states have now outlawed phosphates in detergents, when the new stuff meets the old that is still in your dishwasher lines it makes the film happen. Fill a cup with vinegar and place it on the upper rack, then run it with no other dish's in it on heavy duty, the water will be displaced from the cup during the wash and will help to stop the film. I had to do this 7 times before the film stopped, good luck
Jan 21, 2011 | KitchenAid Dishwashers
Detergent door won't open when it cycles through a wash
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
Jan 06, 2011 | KitchenAid KUDS30IVBL Builtin Dishwasher
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Soap dispenser does not open during wash cycle
  • Hi,
    please try this...
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Apr 14, 2009 | Dishwashers
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch slimline dishwasher flooded kitchen
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
118 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
