Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
No acceleration I have a 75 horse power evinrude outboard starts and runs great out of the water idles and goes up throttle like a champ on the hose but as soon as I get in the water it falls on its face I have to pump the choke to get it to run good.It will only run good for a couple minutes then it falls again hit the choke and it runs great again for a couple minutes and continues this way.I thought if I ran it a while it would line itself out but it hasn't.any help would be appreciated thanks
  • Anonymous Apr 24, 2009
    johnson gt 150 1988 starts and idles well but wont come out of the hole without bumping electric choke and continue to bump choke from time to time and I have used additives to get the water out of fuel.
  • 285 Answers
I'd be checking fuel flow. Usually if you have to choke or squeeze a primer bulb to keep it going, the motor isn't getting enough fuel. Check all fuel lines and connections are air tight, then if problem persists, investigate fuel pump.
A good carburettor cleanout and new carb overhaul kit wont hurt either.
Posted on Mar 03, 2009
1987 15 horse Evinrude motor
rebuild the carburetor.
Sep 06, 2016 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Size of prop for 1994 evinrude 90 horse power boat
Hi, it would probably need a 17 inch pitch and then water test it and make sure its full throttle revs are between 5200 and 5500. regards Phil.
Aug 16, 2012 | Clymer EvinrudeJohnson Outboard Shop...
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Aug 28, 2009 | Boating
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
648 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Are you a Light Boating Expert? Answer questions, earn points and help others
