Question about Apple BTO PM G5/1600 Mac Desktop
Tower wont post
I have 2 powermac g5 dual 2.0s that dont work and one 1.8 that does can i transplant the processors into the 1.8
    President:
  • 2,653 Answers
Yes.
Posted on Feb 28, 2009
Can a apple powermac g5 with a 2.5 processor with a 1TB solid state drive run OS 10.11 ?
No.
The highest OS a G5 can run is 10.5
All OS versions after that are for Intel processors only
May 26, 2017 | Apple Computers & Internet
Powermac G5 screen shaking
This sounds possibly like a power related issue. If you are using a simple power strip to plug into, consider replacing it with an Uninterruptible Power Supply (aka Battery Backup, UPS). AC power related issues can cause screen waviness or shaking. Be sure to obtain the proper capacity unit for your needs. These units are rated in Volt AMPS and come in sizes from 300VA to 1500VA in the consumer product line. APC, Belkin, Triplite, CyberPower are some popular brands. The VA capacity to choose should be considered over price alone. Buying the cheapest one vs the right capacity can result in not having a unit capable of protecting your devices plugged into it. Understand these have 2 primary functions,
1. surge-protection
2. battery backup during a power related problem
There are 2 different banks of receptacles on these units.
1. Some for surge protection AND battery backup
2. Some for surge protection ONLY
Your computer would be plugged into the surge AND battery backup receptacles. When a power related incident occurs, the unit quickly switches the devices plugged into these receptacles off of AC power to the batteries, until the power issue is resolved. The time on battery is limited based on the VA capacity mentioned earlier in this solution. So buying the largest VA capacity unit you can afford will simply give you more available time on battery before the batteries are exhausted and must be recharged. On the other hand buying the smallest VA unit could result in an immediate and unexpected shut down of the computer if a power related issue occurs and the battery backup cannot handle the devices plugged into it. NEVER use these units for battery backup of Laser Printers or other high curent devices. These can destroy the battery backup.
I hope this helps with your screen issue.
Apr 15, 2013 | Apple Power Mac G5 Desktop
Video jitter on youtube on power pc
Try using the browser Google Chrome, it has flash built in and it is a bit faster.
If this doesn't work, you'll have to kill some programs to get more processing power. Press and hold the command key, and then tap tab while still holding command to cycle through your running programs. Let go to stop on one you kill, and then press Command + q to kill it. Do this with as many programs as you can to get better performance, you can always start them up again later.
If none of this works, you may need to upgrade your graphics card...sorry.
Apr 14, 2012 | Apple PowerMac G5 Dual Mac Desktop
My G5 Mac takes a long to start up and the the fans go wild. It's real slow. I ran a diagnostic check and everything passed. I have 80 GB left of hard drive space. Some programs are not working either.
This is a common issue for G5s. The quickest solution is to open up the computer to see how much dust there is built up inside of the case. If the case has a lot of dust by the fan vent, then it cannot properly get rid of the heat that builds up from processing. Try cleaning that out.
If the computer continues to run hot, there may be some much more major issues, including ram, processor, or hard drive. Ram and hard drive issues are relatively cheap to fix, you can purchase new ram dimms or hard drives on amazon.com or crucial.com. Processors are much harder to replace and it's likely that it would be easier to purchase a new computer, rather than a new processor.
Start with the dust issue, then go from there.
Dec 04, 2010 | Apple PowerMac G5 Dual Mac Desktop
Power mac g5 shows terrible damage in tower from leaking they swear mom board is fine but its hard to believe. are any of the other parts usable for a g3 to g5 imac or g4 powermac or emac
None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
Oct 31, 2010 | Apple iMac G4 Desktop
PowerMac G5 with dual 2.7 processors powers on but no video
There are seven diagnostic LEDs near the memory banks of this model: six in a tight line between the edge of the logic board and DIMM bank 1, and the seventh just underneath DIMM bank 1 and slightly more inboard. Please tell me which of these LEDs are on and I will tell you what they mean.
Sep 25, 2009 | Apple Power Mac G5 Desktop
PowerMac G5 fan keeps running -- LOUDLY
I had the same problem... It is the logic board... You need to get it replaced. One way you could try to fix it by resetting the board there should be a little black dot behind the front two fans when you open it up. Press and hold for a few seconds... this resets the board to factory settings. The other way is replace the internal battery. and the third is to replace the logic board. $150-200
Jun 04, 2009 | Apple PowerMac G5 Dual Mac Desktop
How to replace the power supply on a powermac G5
I would be very cautious doing this, if you are not an Apple tech. You can damage the connector for the G5 Processors, and render the machine un-usable.
You have to remove the RAM and Processor, then remove the two power connectors that connect from the power supply to the logic board. On the bottom, underside of the chassis, there are four screws. Remove them, then you can tilt the power supply out of the bottom of the unit.
Replacement, is just the reverse.
Apr 17, 2009 | Apple Power Mac G5
Power Supply blew up, need to replace
Hi, Sorry to hear you are having problems,
Here is a very useful website:
http://g5.bhmm.net/
it will show you how to take apart a Powermac G5 step by step.
Mar 16, 2009 | Apple PowerMac G5 Dual Mac Desktop
Apple BTO PM G5/1600 Mac Desktop Logo
85 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
