Question about Arrow FASTENER CO T50XP "NAIL SET ATTACHMENT" STAPLE GUN
Staple gun for Arrow T50 will not work. Have two
Staple gun for Arrow T50 will not work. Have two of these. Put staples in and staples will not come out. Have used these for years. We know we have the right staples. Can't take apart. Have no directions. Don't see any signs of staples being jammed.
  • Anonymous Mar 22, 2009
    The metal part that pushes the staples out is stuck in the "pushed" position. I do not know how to remove the bolts that attach the front piece to see if I can fix it.
5 Suggested Answers
  • 384 Answers
SOURCE: My T50M Staple strips break up in the gun and jam
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Posted on Jun 12, 2009
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
  • 32 Answers
SOURCE: my arrow staple gun jams every few staples even
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Posted on Nov 10, 2009
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
The door at the back of the staple gun won't close
You have too many staples in the gun. Chances are it was not shooting staples so you put more in. (Only holds 1 strip as if new from box) Check for a jam. Sometimes this keeps more staples from advancing. Please rate
Jun 05, 2009 | Arrow Fastener Co. Hd Staple Gun - T50
Arrow FASTENER CO T50XP "NAIL SET ATTACHMENT" STAPLE GUN Logo
468 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
