Question about Toshiba SD-P4000 14 in. TV/DVD Combo
Need remote codes for Toshiba TV/DVD combo Model sd-p4000
Can't seem to get my Direct Tv universal remote programmed to control the TV on/off or the volume. I've tried all Toshiba tv codes and the one listed for DVD.
Any help is much appreciated.
Code list for philips remote for my toshiba TV
Posted on Apr 01, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
What do I have to do to control my Toshiba 50L3400 tv's volume with my direct TV remote
You should set it up with the set-up codes to Toshiba brand TVs. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 18, 2014 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
I cant program my rca remote on the tv
Hello
Setup codes for Toshiba TV with RCA RCR 311B remote control are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
Most RCA universal remote will have this code for Toshiba TV.
Programming method:
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1* Manually turn on the component
you want the remote to control.
2* Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4* While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5* After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
OK.
Jul 14, 2011 | Toshiba 27A45 27" TV
I got a remote control for my tv cant change channel
Did you attempt to program the remote with the tv? Is it a universal remote? If so, most remotes come with a list of codes to try with most tv's. Does the volume work? Can you type in a channel direct... pressing 5 for example? If those work but not the up/down channel, the remotes faulty. Or is it set to tv or cable?
Sep 28, 2010 | RCA Universal Remote Control
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Nov 08, 2007 | Toshiba 14DLV75 14 in. TV/DVD Combo
someone esle found this.. and it worked for me
Oct 01, 2007 | One For All URC-3021 Remote Control
Toshiba SD-P4000 14 in. TV/DVD Combo Logo
1,051 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
