Question about IBM ThinkCentre A50p PC Desktop
Lenovo system - Viewsonic display CONFLICTt
Hi I have Lenovo IndeaCentre K210 system with 3GB RAM, 500G HD with a video adapter/card integrated in an Intel Chipset31/33 along with a Viewsonic VX2433 Model VS12324 monitor and there appears to be a conflict / incompabilty problem somewhere.
The displays does not performing properly by that I mean that some pages either are cut off or overlap, when I open some applications the lines on the display do not line-up properly, for example when I open Taxcut, if there is a YES and NO box to be checked off, the YES box would line up next to the NO Box and the NO Box would line up under the NO box (next to nothing), instead of being next to the NO Box.
This is not only annoying but creates lots of problems especially when I am working with the Taxcut program because with things do not line-up properly, I am not sure where the correct entry should be made?
The Lenovo system and Viewsonic display are relately new (3 months) and I updated the Viewsonic VX2433 driver and installed the most current Intel Chipset driver but the problem still continues.
I contacted Viewsonic and they advised me "the lining up of the boxes is coming not from the monitor but the incoming signal (video card issue)" so it apperas that Viewsonic is advising me to purchase a new video/graphics adapter but when I check the specs for the video adpater on the Intel Chipset, it should be more than capable of supporting a 16x9 format 1920x1080 display.
Lenovo has replaced the Motherboard and the Viewsonic display has been exchanged so my guess is that whatever is causing this problem is probably not due to defective HW but by a SW conflict and I would appreciate your help.
Obviously the first question that I have is WHAT is causing this problem?
The next question would be what can I do to fix it?
Also, do I really need a new video adapter as Viewsonic suggests or is the problem be caused by the Viewsonic driver and I should look at getting a new monitor?
Thank you in advance for your help,
Bob
Bob
  • 12 more comments
  • forregistry Mar 03, 2009
    I appreciate your help and thank you for getting back to me Raph, from the little I know, I thought taht this was a software conflict as well unfortuantely Lenovo, Viewsonic and (MS) Vista all point the finger at someone else and basically say "not me" so I tried to instal vga.sy.driver but couldn't find it on the MS Website. Can you please provide me a Website where I can download this driver (I assume taht it should be easy to uninstall the Intel driver and install the vga driver using Device Mananger). Thanks Raph,
    Bob
    I would like to apologize to you Beamsabre, I did not notice your reply and wrote to Raph. Believe me, I need ALL the help I can get so I did not intentionally ignore you, sorry. I changed the settings to 800 x 600 (very hard to work with) and opened the Taxcut program and the lines/boxes were NOT aligned properly (the same as they are when the display is set at 1980 x 1200). I woudl like to add one more bit of information which is that there is a Taxcut Personal and a Taxcut Business program, the Personal program works fine (everything is aligned), it's the Taxcut Business program that is not aligning properly. Also, Taxcut Business is not the only program/application taht does not align properly. When I open My Yahoo (which I use for my Home Page), some of the text at the begining of a paragraph either is cut off or partly displayed and soem icons are "all over the place" (i.e. not where they are suppose to be). Hope this helps Beamsabre and again, I apologize for the oversight. Bob
  • forregistry Mar 04, 2009
    Thanks guys, I am using Vista HP and I did try BeamSabres suggestion and "the problem" still exists even when the resolution is set at 600x800.
    Thought this might help
    tall
    Hey guts, a little more news (info) to report. I unistalled the Intel Driver and Vista installed (and ran) the vga driver and 2 things to report, the resolution on the screen was terrible (but I am sure you expected that) and the aligning problem still appeared.
    I then reinstalled the Intel driver and noticed something interesting when the system rebooted. Persistence Module has stopped working appeared during start-up and I also noticed a "Media Test Failed" message. I don't know if this means anything and/or is helpful and would appreciate your thoughts? Also, I am a "give a man a fish..." type of guy so if you can also provide a little explaination I would appreciate it and it might help me resolve a similar situation if it occurs again. Thansk, Bob
  • forregistry Mar 05, 2009
    Hi Raph, when I removed the Intel Driver, the *default) vga driver did run and terrible is giving it too much credit. The Intel driver is now re-installed.
    Any plan "B"? Thanks, Bob
    Hi guys, thank you again for all your help and I think I've uncovered something that is important and unfortunately I don't know how to interpret it (figure out what to do).
    I thought I noticed this yesterday but wasn't sure so I went back and re-ran the exercise of removing the Intel Driver, installing the VGA driver and the re-installing the Intel Driver and after the system restarted, I opened the Taxcut Business program (that was not aligning properly) and it was fine see attachment. So my guess is that the Lenovo system and Viewsonic Monitor get along fine but something apparently is updating once the Intel Drivers have been installed causing the conflict. Like I said, I am a little further along than a novice so I don't know if I am interpreting what is happening correctly and would appreciate your analysis of the situation and possible remedies. Also, I was planning on returning the Viewsonic display but am not sure if another display would be any better since the Viewsonic display works fine for awhile and then "something happens" to make it go out of whack. Thanks, Bob
    Hi, I've got another observation taht I hope might help you help me.
    When I look at my Home Page (My Yahoo) I notice that in the Driving Directiosn module that there is data superimposed in the ORIGIN and DESTINATION boxes. This apparently is another example of improper "alignment". BTW, the Taxcut Business progarm still is displaying / aligning properly so whatever update is creating the problem has not been made.
    Thanks,
    Bob
  • forregistry Mar 06, 2009
    The Viewsonic VX2433 is a 24" diplay / 16x9 screen and the resloution is set 1920 x 1080 at 32 bit
    Hi Raph, I've tried setting it at 1920x1200 several times and "the problem" still occurs. Further, I get a message (I assume from Viewsonic) advising that for best resolution the motitor should be set at 1920 x1080.
    Thanks,
    Bob
  • forregistry Mar 07, 2009
    Hey guys, I made another observation that I think would be helpful. When I was viewing My Yahoo Home Page with lots of "modules" on it, there are numerous areas where icons are tranposed from other modules (see the ScreenShot of the TV listing that I previously posted for examples), I click on Refresh and noticed that all the icons that were in the wrong places, moved back to the correct positions while the screen was refreshing and as soon as it stopped refresh, they went back to the wrong areas i.e. superimposed as they are on the attachment. I don't know how to interpret this but I believe that it is important and wanted to share it with you guys.
    Thanks,
    Bob
    Hey Raph, I had to do a little modification (reduction) on the attachment due to the 150KB limitation but I think it demonstrates the problem. Look under Boca Raton (Weather), above bookmarks and below Travel (Personal Assistant) and to the right of MSFT (Stock Protflio Watch), and you will see the 3 icons that have "relocated / moved" and are superimposed in areas that they are not suppose to be.
    As I mentioned, when I REFESH the My Yahoo page, these icons revert back to where they are suppose to be but Refresh only takes a second or so and they revert back to where they are in the Screen Shot when the Refresh is complete. The icons are suppose to be as follows: the one in Boca Rtaon ----> in the long Blue recutangle to the left, the one by Trave----> in the long Blue rectangle labels Weather Forecast and the one by MSFT---->in the long Blue rectangle to the left labeled CNN.
    Let me know what else I can do and for my personal knowledge/education, please advise what your thought process is in trying to figure this out?
    Thanks Raph,
    Bob
    Thanks,
    Bob
    Sorry, I see you also asked "are you encountering this on all programs or only on a specific". The Yahoo Home Page is full of these little glitches, the Taxcut Business progarm has the check off Boxes aligned incorrectly and when I read some articles on some Website sites (NYT, WSJ, SI...) the text on the first line sometimes is cut off (i.e. a spacing problem, the text is larger than the space allocated but line 2, 3 .... are file, only the 1st line is out of whack).
    Thanks,
    Bob
  • forregistry Mar 11, 2009
    Any further thoughts guys?
    Thanks, Bob
  • John Miller Jr May 11, 2010
    Can you see the display to reduce the resolution? Start at 800 x 600. See if things are clear here. I suspect with these specs you have Vista. Now test each resolution setting until you cant see the monitor clearly. If the display messes up, wait 15 seconds and it will change back to the last setting. I have to know: is there a reason for such a high resolution in the first place? Beyond 1600 x 1200 is a waste...
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Yup. possibly a SW conflict. what you can do is to uninstall your video card driver and see if it runs properly under vga.sys driver (microsoft default) if it doesn't run, then you have a hardware problem.
you can come back to me anytime if you need more answers.
Posted on Mar 03, 2009
  • 4 more comments
  • Raph Quintos
    Raph Quintos Mar 04, 2009
    you dont' need to look for it. Since vga.sys is the default driver for microsoft (once you uninstall the videocard driver. It will be used by default. Even before or while installing windows. Btw, what version of windows are you using?
  • Raph Quintos
    And maybe you can follow the advice of beamsabre since this is the primary problem of most widescreens (setting the right resolution)
  • Raph Quintos
    Raph Quintos Mar 05, 2009
    I guess this indicates that a test has failed. Basically this is usually normal (unless you're experiencing problems) btw, when you used the default driver (vga.sys) did it ran? it should be running. I know its terrible but because we need to identify where's the problem.
  • Raph Quintos
    Raph Quintos Mar 06, 2009
    can you give me your LCD screen size and your resolution range (the minimum capacity is 640 x 480 or even 800 x 600
  • Raph Quintos
    can you set it on its maximum resolution? and check. If something happens, you can press esc key.
  • Raph Quintos
    Raph Quintos Mar 07, 2009
    then can you give me the screenshot of your desktop i may see what the problem really is? are you encountering this on all programs or only on a specific?
What is visual graphic acdactor ,and the freze
A video card (also called a video adapter, display card, graphics card, graphics board, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display. Most video cards offer various functions such as accelerated rendering of 3D scenes and 2D graphics, MPEG-2/MPEG-4 decoding, TV output, or the ability to connect multiple monitors (multi-monitor).
Video hardware can be integrated into the motherboard or (as with more recent designs) the CPU, but all modern motherboards (and some from the 1990s) provide expansion ports to which a video card can be attached. In this configuration it is sometimes referred to as a video controller or graphics controller. Modern low-end to mid-range motherboards often include a graphics chipset manufactured by the developer of the northbridge (e.g. an AMD chipset with Radeon graphics or an Intel chipset with Intel graphics) on the motherboard. This graphics chip usually has a small quantity of embedded memory and takes some of the system's main RAM, reducing the total RAM available. This is usually called integrated graphics or on-board graphics, and is usually low in performance and undesirable for those wishing to run 3D applications. A dedicated graphics card on the other hand has its own Random Access Memory or RAM and Processor specifically for processing video images, and thus offloads this work from the CPU and system RAM. Almost all of these motherboards allow the disabling of the integrated graphics chip in BIOS, and have an AGP, PCI, or PCI Express slot for adding a higher-performance graphics card in place of the integrated graphics.
Aug 31, 2012 | Computers & Internet
Specs say the Lenovo G560 067999U has max memory of 8gb. ordered 2x4gb for the total 8 upgrade and it won't take the 8. it will see 6gb not 8. did anyone else come up with this issue?
Hi, i have same notebook but not the same problem.
Maybe your graphic card taking some of memory or they make mistake in the PC shop.
Download CPU-Z utility http://www.cpuid.com/softwares/cpu-z.html (download is on the right side)
Run it and go on Memory tab where you see your total RAM memory then you can go to SPD tab and see what memory exactly is installed in every slot.
Hope it will help you :)
May 20, 2011 | Lenovo G560 067999U Notebook
Can i connect a video card on my acer aspire 5740?
i think you can, but this laptop has great integrated graphic card, it use Integrated Intel® HD Graphics or Discrete ATI Radeon™ HD 5650 graphics or Discrete ATI Radeon™ HD 5470 graphics
this graphic card can make great picture for HD video
Feb 05, 2011 | Lifetime Acer Aspire 5740 Replacement...
Sir, i have 512 mb ram with pentium4 .i need vga driver ,from which site can i download it????
The driver depends on the video adapter that you are using. If you are using the integrated one, you need to get the motherboard manufacturer/computer brand. If it is a stand alone card, you need to get the model of that video graphics.
Oct 27, 2010 | Computers & Internet
4gb ddr2 ram installed but only showing 2.5gb using windows 7 64bit ultimate
Do you have a video card? If you using integrated video. the integrated video use the 1.5gb memory of your ram. to check how much your video adapter use.. Goto windosws start -> setting -> control panel -> Display -> Setting -> Advance -> Adapters, you will see the memory size.
Aug 24, 2010 | EliteGroup P4M900T-M (V1.0) Motherboard
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Feb 18, 2009 | ATI Diamond Multimedia Stealth RADEON HD...
Video cards
HD 3200 is an onboard (shared Memory) graphics chip
Dec 01, 2008 | ATI FX5200 Video Card 128 MB Ram AGP...
NO DISPLAY
Hi m_o_redz,
If you are using the on-board (integrated video), S3 Graphics Chrome9 HC Integrated Graphics core. Than check you're video cable, video cable connection. Try another monitor. If all check out ok than the MSI integrated video is defective. Suggest you install a PCI-E video card.
If you are using a PCI-E card, try removing it. Clean the copper contacts using a cotton swab & alcohol. (Let it dry) Than reseat the PCI-E card.
Try booting again.
Good Luck!
Mike
Apr 22, 2008 | MSI P4M900M-L Motherboard
IBM ThinkCentre A50p PC Desktop Logo
589 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
