Question about Toshiba Satellite P105-S6227 Notebook
Getting online with ethernet cable instead of USB.
I'm having trouble connecting to the internet with an ethernet cable instead of a USB cable. Are there settings on my laptop that need to be changed when switching cable types between modem and computer? If so, what are the steps?
I cant find any repair kit for error rundill , 405napster or ccc incompatible ati graphic adapter or sign in error
Posted on Feb 28, 2009
  • 82 Answers
Yes you need to install LAN driver first ..you can find it in toshiba site
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Dear sir i have probs with my mobily usb connet, when iconnet the mordam my google talk online offline contact not showing
if you mean trouble with modem internet connection
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 03, 2011 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
We re booted the computer and have to use a usb
Not sure what the problem is, but from what i am reading i am suprised that anything worked at all. A modem jack in your computer is for telephone lines, and the cable modem needs a cat 5 network cable as well as a ethernet card attatched to your computer. ethernet card in your computer cat5 cable runs from the card to the cable modem. Magic jack requires a usb connection as well as a broadband connection to work.
Dec 01, 2009 | Acer Computers & Internet
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a t mobile usb internet stick which i use to get my internet trhough my pc,and i have an ethernet cable that goes from the pc to my ps3 .everything works fine the internet connection on the ps3 is...
Only router can give you proper NAT settings that can allow you to play online. Since you have a USB internet stick, try to buy a USB to Ethernet converter first. Then you can now use a router
Jun 10, 2009 | NetGear WGR614 Wireless Router
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
I am having problems at times, connecting on the internet, and other networks online. (i.e.)an icon would appear and suggest an error/data was made and being reported, and automatically swicth me back to...
Cable has changed it's policy and standards many times in the past
if you have a cable modem you will most certanly need to decide
if you're going to be using the cat5 ethernet connection or the USB connection cable
if you have an onboard ethernet adaptor or a PCI ethernet adaptor
it's best if you use the cat5 connection of the cable modem
if you have no ethernet adaptor , you will need to use the USB connection of the cable modem
and connect that to your computer , which will most deffinately require that you have working
USB ports and at least service pack 2 loaded to enable USB 2.0 , and a driver from the cable
modems driver CD
if you're using a router , use the cat5 connection of the cable modem
( make sure you contact your ISP to walk you through the setup proceedures )
Az Selah ..
Sep 17, 2008 | Computers & Internet
Bought a new computer with vista instead of XP and cannot connect to internet via the ethernet line from my cable modem. what is the secret? Usually plugging it in is enough when I have moved or changed...
Yes! plugging it in on the Ethernet cable on the modem to the computer should get you online. If your not able to get online, you may want to check the following:
1. Make sure that the Ethernet adapter on the computer is enabled. If you can't find the Local Area Connection icon in your Network connections (control panel\network and sharing center), check if the network adapter is properly installed.
2. Some cable service providers require the MAC/Physical address of the Computer to get it online through the modem. If the old computer is working with the modem, you may want to contact your ISP and ask their assistance in getting you online using your new computer.
Aug 02, 2008 | Gateway Computers & Internet
Open Questions:
See all Toshiba Satellite P105-S6227 Notebook Questions
Toshiba Satellite P105-S6227 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
