Question about Dell Axim X30 Pocket PC
Delll axim x30 screen remains dimmed even though fully charged
My dell axim X30´s battery went completely empty the other day cuz i forgot to charge it, the thing is once it was fully charged again, the screen remained dimmed as in lo batt mode, i have alreadychecked brightness and for some reason it remains dimmed, i cant see anything on the screen because it went so dim. I tried to reset it and the screen lights up normally at the beginning, it says DELL on a blue screen like it used to normally but then it goes dim again so i can barely see what's on the screen. HEL PME PLEASE !!! this is vital for me !!!
    Problem Solver:
  • 10 Answers
Ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Posted on Mar 27, 2009
I have a dell axim pda that I hadn't used for awhile. I charged it and saw green light, but when disconnected charger the light went out and still can't turn on. Purchased new battery and sa
LCD cable is loose inside, need to be opened up and reseated or replaced, or replace main board, if under warranty call DELL support to request onsite tech to repair.
Sep 29, 2017 | Dell Axim X30 Pocket PC
Backup battery
its in the back of device a slight curved flap is given just lift that flap and its there.
Sep 18, 2008 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
Power button flashing
Clean the battery connectors on both sides, so on your Axim and on your battery.
Also try to push the battery against the connectors, maybe put a sheet of paper between it or so.
Mar 28, 2008 | Dell Axim X50v Pocket PC
Axim x30 screen blanking
I've seen this twice>
take battery off pc and plug it in.
if it stops replace the battery.
if it does not your charging circuit in the pocket pc is gone south.
Mar 14, 2008 | Dell Axim X3 Pocket PC
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Backup battery problem
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Sep 04, 2007 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
310 people viewed this question
Alun Cox
