Question about Panasonic PT-52LCX65 44" HDTV
Reset lamp counter on PT-52LCX66/PT no PIP or split key on remote
  • 1 more comment
  • bapu 649 Mar 15, 2009
    i have problem after replace lamp
    lamp metre to resist
  • paul212 Apr 12, 2009
    How to reset lamp timer after lamp replacement?
  • FMRDDOG May 18, 2009
    I HAVE A PANASONIC PT-52LCX66 AND I NEED TO RESET THE LAMP TIMER. I DONT HAVE PIP ON REMOTE.
I aswell dont have PIP on remote but i found another way to fix....
hold the volume button ON TV - down and the 0 zero button on remote at same time :) just worked for me...
Posted on Jul 29, 2009
I have a universal remote for my Panasonic PT-50LC13 and I need to reset the lamp hours. Can anyone help?
I too had a problem resetting my lamp time of my PT-50Lc13. My remote that came with the set lacked a PIP and SPLIT keys, BUT....my charter remote (that was obviously configured for my set via codes) has a PIP ability that we discovered some time ago. Instead of using the STANDARD remote, you can use a UNIVERSAL that has a PIP capability....has to be set up to work with your set first....you can hold down the VOL - key and the UNIVERSAL remotes PIP key for about 5 seconds and then you will receive a message stating that the lamp time was reset to 0.
I know this helps someone out there, and your welcome!
Oct 24, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
How do I reset a lamp counter on a PT-52LCX66/PT TV?
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Feb 20, 2010 | Panasonic PT-52LCX66 Projection Television
I can't reset the hour counter and I have no sound
The buttons used are the TV's volume down and the remote's number 0.
As for sound, more info is required.
I hope that helps.
Dec 26, 2009 | Panasonic PT-52LCX66 Projection Television
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
The lamp hour meter needs to be reset for Panasonic PT-52LCX66 Television. How do i reset it?
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-52LCX66 Projection Television
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
I hope that helps.
Oct 10, 2009 | Panasonic PT-52LCX66 Projection Television
On my pt 52lcx35 it says the lamp hour meter needs to be reset.
press the down volume on the tv at the same time press the up dvd/vcr split button on the remote. do this for at least 5 seconds and it should reset
Apr 02, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-52LCX66 Television lamp reset time
With tv 0n press vol- (minus) on tv and hold. then hold 0 on remote hold both for about 5 sec.
Feb 22, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
2,121 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
