Question about iLO 2600 Television
My big screen tv has almost completely lost it's volume. It's turned all the way up but you can hardly hear it. The remote works fine and the picture is great. Just lost most of the sound. What gives.
  • maryvw50 Mar 02, 2009
    My ilo tv has just lost it's volume also. We tried hooking it up to a Bose sound system but it still has no sound. Do you think taking it to a repair shop would be costly? It's only 4 yrs old and I don't think it should be dying so soon.Please advise,Thanks.
    Sergeant:
  • 319 Answers
Sounds like the amplifier board has gone bad. If you have an external home theatre, i suggest routing the audio through that, as the boards can be pricey
Posted on Feb 28, 2009
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
I lost the remote...is there another way I can change the screen format?
1.Go to menu
2. using the volume button scroll down to picture options or screen reset.
Jan 02, 2015 | Televison & Video
I have a tv/dvd flatscreen televsion. It is only a year old. The problem is I can not hear anything. My television is displaying the screen and movies/television is working fine, just no volume. Please...
Does the the little bar graph on screen volume display react when you turn the volume up and down or does it say something like TV VOLUME IS FIXED?
Try using your remote to look in your tv's MENU for the AUDIO OPTIONS.
Check to make sure the SPEAKER option is turned ON.
If that doesnt work, try running a cable from your tv's audio out jacks in the back to one of your home stereo's AUX inputs and see if you can hear the tv through your stereo.
Good Luck.
Jan 20, 2011 | Televison & Video
No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Apr 02, 2010 | Vizio L32 32 in. LCD HDTV
No picture on a Toshiba 46RV530U
Turn the tv on and shine a flashlight on the screen. Its hard to see a pic but most likely, its there. For some reason, your lamps in the panel are not turning on. Inverters are my first guess.
Dec 02, 2009 | Toshiba REGZA 46RV530U LCD TV
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
63 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
