Question about Casio Exilim EX-Z750 Digital Camera
Power button will not work - it did not pop up when depressed. I removed battery and card and re-inserted but button is still stuck. Any suggestions?
  • trailrider22 Feb 28, 2009
    Battery needs to be charged.
  • Anonymous Mar 14, 2009
    brand new battery, willnot start
    negative side inserted right way- on button looks low in housing
Found out that if battery needs charging, camera will not turn on at all. I guess I had a senior moment. Button was not stuck just no power to turn on camera. After charging battery everything is fine.
Posted on Feb 28, 2009
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
Err 99in my canon 1000D
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Jul 18, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
camera body.
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 when I attach lens
I had the same problem with my camera and i found this guide online very helpful in most cases
camera body.
Jan 29, 2009 | Canon EOS-10D Digital Camera
When trying to take a picture, I get an error 99 on my Canon Rebel.
To isolate the cause of the issue, it is suggested that you do the following:
camera body.
I hope this helps!
Nov 17, 2008 | Canon Cameras
Error 99
camera body.
if the solution helps .
please rate the solution.
thanks.
Nov 05, 2008 | Canon Cameras
Err 99
Hi Ben ,
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
My Canon 20D suddenly started saying "Error 99" and it won't take any pictures. What should I do?
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
Aug 06, 2008 | Cameras
Casio Exilim EX-Z750 Digital Camera Logo
175 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
