Question about Homelite Mighty Lite Lawn Trimmer
On pulling the starter coed it will not return
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
I have a ryobi hedge trimmer RHT 2660 DA why wont the pull cord wont return ?
If you can try and tap by the starter housing with a small hammer and then you need to get some lubricant spray injected in to the spring. If it wont go back in there is a chance the spring has either broke or become unseated.
Jul 28, 2014 | Ryobi Garden
I have the toro ccr 2450 recoil start snowthrower and the recoil starter is not pulling properly. It's very hard to pull for some reason and shouldn't be frozen. It will allow me one smooth pull and he...
You have to understand its a cord spulled around a recoil spring. The coed likely didn't rewind correctly one time. However the entire unit unbolts with three screws.Remove the unit from the engine and check the cord and realine the core raping path as well as check the return recoil spring function. If you can not realign you can replace the unit as a part. After the first pull the engine has pressure to and that makes it harder to pull to.But try re alinging the assembly i have to do it to mine and its a 1964 and it still works
Dec 13, 2010 | Garden
I need to replace a starter in a 1999 chevy k2500. It was replaced but the starter is faulty and doesn't work only worked for a little while. Is there a manual out there to show me how to remove the...
First thing disconnect the battery terminal.There is a postive wire that is attached to the starter that should be a 13 mm, and pull of the negitive connectio to the starter. There will be no more than two to three bolt to remove on the starter. Problem solved, in less then a half hour.
Oct 08, 2010 | 1995 Chevrolet K2500
Pull string won't recoil
Sounds like the return spring has either broken or come loose from an anchor point. Remove the entire starter mechanism from the saw and pull at the cord. The problem should be evident once you can see what is happening. It may be a kink formed in the cord that prevents return. Good luck!
May 23, 2010 | Poulan 18" Wild Thing Chainsaw
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
May 21, 2010 | Craftsman Garden
The kick starter wont return on my 88 yamaha yz 250
If you can pull it back easily by hand, means it is not siezed where the shaft goes through the cases. so it may need a new return spring, you will have to pull the RHS cover off
Apr 24, 2010 | 2003 Yamaha YZ 250
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Recoil starter will not engage engine when stater rope is pulled
The tooth/notches in the housing are worn out or broken,if the pull cord returns to the original position than the return spring is still good and you will only need to worry about replacing the gear/housing that attaches to the crankshaft .Good luck on the repair job ..BOB
May 02, 2009 | Craftsman Garden
Homelite Mighty Lite Lawn Trimmer  Logo
132 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
