Question about Toshiba Televison & Video
Toshiba model CF30E50, have problem with picture shrinking on the horizontal. problem comes and goes but getting worse.
  • 556 Answers
SOURCE: Toshiba 3387DB Television
it is due to 60Hz HUM IN POWER SUPPLY. please check for input supply. also check for mains filter capacitor in tv. also check for one diode open in rectifier ckt.
Posted on Oct 06, 2007
  • 1694 Answers
SOURCE: Toshiba CF30E50 TV shuts off
Best first step is: Good visual inspection = look for hot spots
on PCB, check caps in those areas + solder any/all bad connections,esp. low voltage regulator pins.Look the whole
board over with magnifier = solder,solder,solder...T.
Posted on Oct 25, 2007
  • 20 Answers
You power supply coil is bad (transformer) prolonged run time causes to heat material as a result of expansion loss of contact no conductivity red light no power
wyoed1
  • 211 Answers
SOURCE: Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Posted on Dec 19, 2008
daniel719
  • 240 Answers
SOURCE: Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Posted on Jan 11, 2009
My picture turns into a white line and comes back if you hit the front bottom of console?
I think you flyback transformer is going out. Eventually it won't come back when you hit it.
Oct 30, 2009 | Toshiba 32A33 32" TV
When the TV is first turned on, thin white lines appear horizontally across the top 4" of the screen. The lines go through the picture, distorting it. After the TV is on for a few minutes, the depth...
On this particular model there is one capacitor from the video process IC (jungle IC) that supplies the Vertical pulse that shoul be changed.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | Toshiba 36A50 36" TV
Power goes on, but no picture or sound??
Maybe the horizontal output goes bad or the flyback are damaged
Oct 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Shrinking Picture
Jan 10, 2009 | Toshiba 36A40 36" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
Oct 25, 2007 | Televison & Video
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
