Question about Mtd Garden
Please help, I need manual in english for my mtd LT31 petrol line trimmer made in usa. Thanks
4 Suggested Answers
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Posted on Mar 17, 2009
  • 123 Answers
SOURCE: need instructions to replace line correctly onto
hi,
get manual fron dis site
http://ubermanuals.com/product/husqvarna-123l-9033
Posted on May 13, 2009
Testimonial: "great,thank you very much."
rycgl
  • 1545 Answers
SOURCE: HOW DO i LOAD TRIMMING
Please see pages 19 thru 23 of your owner's manual. Detailed instructions with diagrams are here.
http://dl.owneriq.net/8/895c4a8d-d94e-49d4-5d45-dc71cf8a717a.pdf
You will need Adobe Reader installed (free, safe, download) installed on your computer to view this.
Posted on Nov 09, 2010
Does anyone have a manual for this petrol line trimmer 2 stroke , and how to thread new line please
only a facebook vidieo
https://www.facebook.com/Nambucca-Valley-Whipper-Snipper-Chainsaw-Mower-Recycling-ServiceRepairs-803906806364452/videos?fref=photo
May 02, 2016 | Garden
What's a mtd lt31 worth second hand
this is kind of a trick question. depending on your location. and the season. if it runs good. my guess it should be worth between $35.00 and $55.00 used weed eaters go kind of cheap. as you can buy new ones at Walmart for $80.00 . it is what you value it at but only what someone else will pay. good luck with your sell.
Oct 29, 2015 | Mtd Garden
HOW DO i LOAD TRIMMING LINE ONTO THE TRIMMING HEAD OF MY MTD LINE TRIMMER MODEL # MTD LT31C REV POO?
Nov 07, 2010 | Mtd Garden
I can't find English version of MTD BV3100 blower vac. manual. Is the oil to petrol 1 litre to 25ml?
http://manuals.mtdproducts.com/mtd/Safety.do?pid=220901&model_num=bv3100&serial_num=1212&filename=bv3100_769-01600_a.pdf
http://manuals.mtdproducts.com/mtd/Safety.do?pid=220902&model_num=bv3100&serial_num=1212&filename=bv3100_769-01601_b.pdf
The manual says 5 liters to 125 ml so yes if you divide by 5,that is equal to 1liter to 25ml That is a 40:1 ratio.
Oct 30, 2010 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
OUR CHURCH HAS AN 18" YARD MACHINE STRING TRIMMER BY MTD. MODEL NUMBER 25A-203L129. NO ONE KNOWS WHERE THE MANUEL IS AND WE NEED TO ADD CUTTING STRING. HOW DO WE DO THIS? 5.0 TECUMSEH ENGINE. THANKS MONTE
The trimmer line is pretty easy to attach. The trimmer line comes in pre-cut lengths, and is threaded in two places through loops on the spindle. (Two pre-cut trimmer lines are needed.)
Oct 11, 2010 | Mtd Garden
What is the 2 Stroke Mix Ratio for a Yard Machine
Most are 40:1 but if you go 50:1 to be safe it will be ok.
Jan 12, 2010 | Mtd Garden
Please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Jul 18, 2009 | Echo Garden
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Dec 22, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
57 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
