Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
My hp pavilion dv2000 screen will not ocme on or reboot. The power led lights are all on. I have taken out the battery and lights stay on. I reinstalled the memory modduls and still nothing
  • mob2324 Mar 12, 2009
    I have the same problem, the machine powers on but the screen does not come on
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend if the pc will not boot. the problems that may occur is in hardware connections and settings. First thing to do try to go to setup utility try to see if the hardisk and other devices are detected there.if not so you problem is the connection. try to change the IDE or the SATA cables. im sure these will solve your prblem. thats all good luck hope i helped you.
Posted on Feb 28, 2009
Power black screen failure hp pavillion dv2000
Normally is because the battery is empty or in an error state.
If you plug the power cord and the led still blinking, disconect everything, turn your laptop and search how to take out the battery, wait 1 minute then replug it again and try.
May 25, 2014 | HP Pavilion dv2000t Notebook
HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | HP Pavilion dv6000z Notebook
No power light on my 6735s hp laptop
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 28, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 Turnoff due to overheating
1) plz go to power options from control pannel and change the power options as never never
2) we can do one more thing,we can do a Bios update
everything tis going to fine
ITS Works
Dec 06, 2009 | HP Pavilion dv2000t Notebook
HP pavilion dv2000 hangs with startup screen and when i do force shut down it gives beeps until i remove the battery and the the light is keep blinking on my laptop
hello..i think their is the problem hardware on the unit..try to remove the memory and try to clean or try to replace..thanks...and Good Luck..^_^
May 13, 2009 | Dell Latitude D600 Notebook
Hp pavilion dv2000 notebook will not boot up
Remove yoru battery off and try powering on with the power cable plugged in.
Mar 28, 2009 | HP Pavilion dv2000t Notebook
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
310 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
