Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
Posted on Mar 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Burners won't light on my frigidare 30" self cleaning oven...oven works but when i try to light burners i hear clicking but the flame doesn't come on
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on Mar 21, 2013
Anonymous
Master
Level 3:
Answers
1010
Questions
Helped
246960
Points
3078
The clicking sound is from the ignition, but you do not have gas at the burner, I think it could be thermocouple.
5 Related Answers
Anonymous
  • 184 Answers
  • Posted on Apr 04, 2008
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Anonymous
  • 184 Answers
SOURCE: frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Anonymous
  • Posted on Aug 21, 2008
SOURCE: Oven not heating KitchenAid KERC506HWH3
I have a one year and 2 month old KitchenAid KEMC308KSS03 Wall oven/microwave combination.
After a self cleaning cycle the oven would not heat again. Eveything else works fine the microwave, controls, etc.
The problem is the thermal limiter switch that KitchenAid used. It is a one shot thermal limiter that opens if the back of the oven goes above 120degrees C and does not reset when it cools down.
The KitchenAid PN is 9759243 BUT don't replace it with the same part if you have this problem. KitchenAid want $84 for this silly thing and it a piece of junk. Buy a PN 317-1368-ND from DigiKey Inc. 1-800-344-4539. This is a 120 degree C thermal limit switch but it will RESET itself when the oven cools down so if it happens again you won't have to pull the oven. This part cost s $6.60 from DigiKey and is a much better part than the original one from KitchenAid.
The switch is on the back of the lower oven, there is a cover that comes off and you will see it screwed to the back with two wires connected to it with faston terminals. It is an easy permanent fix for this problem.
KitchenAid is ABSOLUTELY NO HELP with this (as ususal).
I hope this helps.
Herald
Anonymous
  • 3361 Answers
  • Posted on Mar 18, 2009
SOURCE: Oven flame too high.
Take a 1/2 inch open end wrench and tighten the orifice on the oven gas valve. Then adjust the air shutter on the venturi tube.
Anonymous
  • Posted on Sep 05, 2010
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Frigidare gas oven wont ignite
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
I just refilled my propane gas tanks and gas is coming through the top burners but there is no flame. I hear the clicking sound it makes when the pilot light ignites but no flame at all. What do I do ?
air won,t burn ther is air between the tank & the burner try using putting a flme at the burner then tun on the burner it should start after the air passes through the hose
Oven problem, it tries to ignite, but won't
It sounds like the igniter isn't lighting the flame, or the flame isn't sensing once lit. Check the burner to see if anything has fallen onto the burner or electrodes to prevent it from working. Also check the holes on the burner to see if they are blocked. If it is all clear it may be a control box issue.
1helpful
Burners slow to ignite
you may have your gass set to low or you need a new regulator valve
1helpful
I have a Whirlpool Gas Range with Accu-Bake. On one of my burners the igniter comes on but the burner will not light. You can hear the clicking, but no flame. Is there something that I should clean and...
In addation to the spark do you hear th egas flowing as well? if you do hear the gas and can light it with a match/bbq lighter but it doesn't light with the spark,it could be cleaned by using a safety pin/paper clip and push through the holes where the flame burns all around the burner(s) also steel wool will clean the burner.
Gene
1helpful
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 • Ovens
1helpful
The oven will not light -- I can smell gas and there is a loud burst but no flame. The stove burners do work, however.
With the oven door open, watch the vents at the sides of the floor of the chamber for an orange glow a few seconds after you try to turn the oven on. If it doesn't appear and is similar to other later ranges, it means the igniter has failed. If built as others, it will have hot-surface igniters (one down, one up) and the lower one has failed.
To confirm that this does use the common system, air out the oven first then try the broiler. If it works, you have gas available but nothing to ignite it. Also, you should never get even a distinct thump; this could be dangerous and the gas should not flow without lighting for more than a few seconds.
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
