Question about Pentax *ist DL Digital Camera
Does a Quantaray Tech-10 75-300 lens fit a Pentax *ist DL digital camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 98,902 Answers
Quantaray makes lenses with a variety of mounts. If the lens has a Pentax mount then it will fit onto your camera. If it has a Canon mount, for example, then it will not.
Posted on Aug 23, 2012
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Pentax Ist DL auto focus not working anymore after using Quantaray AF LD 70-300MM Lens
It seems to be a connection issue between the Lens and the Camera body. Perhaps the mount is not true to the body Ask Pentax about this their Technical Support Team
Posted on Jul 07, 2007
SOURCE: AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Posted on Mar 17, 2009
SOURCE: AV flashing in LCD of camera whn zoom attached
Also check that your diaphragm ring on the Zoom lens is set to the "A" position.
Posted on Oct 11, 2009
  • 11967 Answers
SOURCE: Using a 500mm fixed aperture lens on a Pentax ist
Use "exposure compensation" (the button with a plus/minus symbol). It allows you to lighten (toward the + side) or darken (toward the - side).
Posted on Nov 16, 2009
Unable to use SD card higher than 2 GB capacity
If you're using a card larger than 2GB then it's an SDHC card, not an SD card. The *ist DL works with SD cards, which top out at 2GB. Even though higher-capacity SDHC cards will fit into the slot, they will not work with this camera.
Dec 30, 2013 | Pentax Ist D 6.1mp Digital Slr Camera With...
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
Motor whirring but not moving lens on pentax ist d
The lens pins either broke or maybe out of position and not moving the lens..
Here is a tip that I wrote about How to get a Digital Camera Lens to work again
Steps to Repair a Digital Camera Lens
heatman101
May 13, 2011 | Pentax *ist DL Digital Camera
Hi, i have a pentax ISTDL and when i try 2 use it in manual focus the AF still works on its own
Check your lens there is often a AF/MF auto/manual focus switch
Other than that it could be a problem with the camera take it to your dealer
Apr 08, 2011 | Pentax *ist DL (W/18-55 LENS) Digital...
The problem is with waking a sleeping Pentax ist dl: touching the shutter button doesn't reawaken it. To enable the ist dl to shoot requires turning off the camera and of course switching it on again.
This is a common problem with all the ist's. Try cleaning the battery contacts inside the camera with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Jun 28, 2010 | Pentax *ist DL Digital Camera
Nov 15, 2009 | Pentax *ist DL Digital Camera
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
Jul 05, 2007 | Pentax *ist DL (W/18-55 LENS) Digital...
Pentax *ist DL Digital Camera Logo
207 people viewed this question
Top Pentax Cameras Experts
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
