Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
How do I install the lamp? how to install bulb mitsubishi wd 62327
I just changed mine and I still have no picture or sound. And the lamp light starts blinking the the tv cuts off. What can I do?
Posted on Mar 22, 2012
The lamp is in the FRONT of the television set. Just remove the bottom front, no screws, and you'll clearly see directions on how to install the new lamp.
Simple, just a few screws.
Posted on Feb 28, 2009
3 Suggested Answers
SOURCE: Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Posted on Nov 02, 2008
  • 476 Answers
SOURCE: I have a WD-62327 Mitsubishi. The indicator light
You are probably correct, but it wouln't hurt to check the lamp that is in there to make shure. You can download your owner's from "retrevo" and those manuals also give the web site for lamp replacement(toll free number) if you want the original or I found union electronics to have a good price on some of the replacement lamps .
Posted on Jul 30, 2009
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator light....now what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen menus.be sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
regards,steve
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Where is the lamp located in a 62" mitsubushi tv dlp wd-62327? am trying to install the lamp and can't find it.
Some of their models require taking off the lower front panel. Some are in the back to the lower right corner. There is a cover about 6x6 that is removed usually with two screws and the same for the front except it will be the lower left after the cover is off.
Nov 17, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Replaced Bulb and sill have red lamp light
no you should not feel any click,the lamp plug
slides into the ballast plug in the groves.do not
force it,you could have the plug upside down or
you need to visually see if the ballast plug is
damaged.you may need to replace the ballast if you still are getting a red lamp error on the
front of the tv.
Jul 15, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD 62327
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
My best gess is the Ballast.
Aug 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Replacing the lamp wd-62327
Did you get correct lamp:lamp part # 915P020010 ?
Sep 07, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
