Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
DC 14 low reach without good suction
I have a DC 14 Low reach with poor suction. The beater bar is clean, filter is clean and cylinder is clean. Do I need to take it apart to do more? What am I missing?
    President:
  • 389 Answers
Not sure, but there are one or two more possibilities. There are so many Dyson models that It's easy to confuse them, but I think the DC14 has a short length of clear plastic tube leading from the beater bar area to the rest of the vacuum system. Sometimes this tube develops a crack, with the result that air flow around the beater bar is reduced. I suggest you check that. If you also have reduced suction from the hose, you will need to remove and inspect for blockages in the U tube at the base of the wand fitment, and also in the inspection port which is to the right of that (two yellow buttons to be squeezed to remove it, I think). If none of this helps, please post more details, if you can, and I'll try again. Good luck!
Posted on Feb 28, 2009
Low suction
We have one of these a few years old without the ball, pull out and see what suction is like with just the hose and the attachment for it, am I wrong and it (yours ) does not have the pull up and out hose? low suction is almost always a blockage in the air path between motor and cannister.
Dec 13, 2012 | Dyson DC25 All Floors Bagless Upright...
Low suction
Hi Megan,
I'm sorry to hear you're having difficulties with your DC17. If it doesn't seem to be picking up as well as usual, you may have a blockage somewhere in the machine. To check for this, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
Although I note you've already cleaned the filter, please see the video below to check you've done it correctly. In normal use, the filter should be washed at least once every 3-6 months in cold water. Don't use detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve your issue, but if you need any further assistance, please call us free on 1-866-693-9766, or email askdysonUS@dyson.com so we can help.
Kind regards,
Jack
Dyson Online Customer Support
Dec 18, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Our Dyson has very poor suction when using the beater bar. Otherwise it seems to have good suction. The beater bar does rotated as normal. My husband has cleaned the filter and has looked along the line...
I'm sorry to hear you're having difficulties with your DC17. Although I note you've already checked for blockages, it's a good idea to follow the steps shown in our online Support guide to make sure everything is correct with the machine:
Please also check that the filter has been washed as shown in the video below - in normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you're still concerned, please get in touch with us directly so we can provide further assistance. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com.
Kind regards,
Jack
Nov 05, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Poor Suction
The flexible hose between the beater bar housing and the connection to the dust bin might have come loose or has a hole in it. Check this hose for your low suction problem.
May 15, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
This vacuum keeps getting clogged in the hose and has terrible suction. The women who helps clean my house won't even use it as it performs terribly. Any suggestions
check vac air filter(not the dirt collection bag) also something could be lodged in hose mechanism so there is always a partial restriction. make sure the beater bar is not set too low. check the dirt that accumulates in bag to see that there is not an excess number of carpet fibers in there. beater bar should be clean and spin freely.
Oct 10, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hi the suction on my dyson hoover has gone very poor. I have cleaned all filters but suction is still pretty poor.Is there anything else i can do?
your problem with Dyson is the reason why a lot of them end up in the trash. here is the link to an article that will help you locate the cat fur, or hair or other debris that is lurking inside your machine and causing you to loose suction
http://www.insanityideas.com/blog/Thursday-24-March-2005
Aug 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
When using my vacum upright its very low in suction, it used to be so powerfull that it lifted my carpet slightly....when using the tools section its as strong as it should be please help, ive cleaned it...
Check the following items:
* The bag and connection - change it if it's full
* Turn the vacuum over and inspect the beater bar area for any clogging. You may have to remove the bottom plate to really clean it out.
* The beater bar and especially the drive belt - this area gets dirty and the belt can wear out after continued use. The brushes can also wear out on the beater bar
Try to work on the vacuum in a well ventilated area. Make sure you unplug the unit so it's safe to service
Apr 27, 2009 | Vacuums
Dyson dc 14
Hi
we had the same problem loads of suction on the pipe but did not touch any thing when in upright mode. The brush bar was rotating but did not seem to be doing anything to the carpet. when we looked at the machine sideways the plate that surrounds the beater bar was not parralell to the floor The front was meeting the foor so from the hoovering position it looked fine but the back was tipping up under the vacuum lifting the brush bar away from the floor and stopping the suction. The only thing that seems to hold this parallel when in hoovering mode seems to be the connection hose from the beater bar into the cylinder (Clear plastic with spirals). This seems to act like a spring to hold the plate paralell. We twisted this through 180 degrees and flexed it a bit and it is now holding the plate parallel. Bingo! beater bar is connecting with the carpet and we are back to great performance. Could not believe it could have such an effect
Our machine is several years old so we might have to get a new hose. However there are no splits in it so we might try a bit of duct tape repair if it goes again as it only seem to be the rigidity of the hose thats rhe problem not the connectors.
Hope this helps
Dec 26, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
193 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
