Question about Palm Treo 500 Centro
How to type an underscore
I am trying to enter an e-mail address containing an underscore to use IM on the Palm Centro 690. I don't find one on the keypad. Is it possible?
Hit the upper key and you will see the underscore key
Posted on Feb 28, 2009
Phone dose have enough space and its not turning on
Increase your data with your provider or buy a memory card.
Oct 28, 2012 | Palm Centro 685 Centro 690
How do I increase the signal strength of my Palm Centro?
The bars show relative signal strength.
If the Motorola is on the same provider, it is the Palm smartphone that is the fault. It may just be you got a less than sensitive one. You should probably contact Palm and see if there is anything they can do short of exchanging it, otherwise exchange it and keep exchanging them until you get one that works. In mass production- these things happen.
If the Motorola is with a different carrier, that may be the difference- they are line of sight devices and the provider you have for the Palm may not have an antenna in your vicinity pointed in the correct direction for you. Which means complaining to the carrier since you know the external antenna works, but the Palm does not.
Jul 07, 2012 | Palm Centro 690 Blue Smartphone for...
How do i get under score on my pda
Type a hyphen (option 's key') then click 'alt' key (underscore should be pre-selected) select (centre palm button).
Feb 17, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
I did not know how to turn off my email connection of my palm centro cellphone
Hello p_belgado,
The email connection can not be turned off but the email application can deleted off the Palm centro if you don't want to use it. It can be deleted by doing the following:
•Press the home button
•Press the menu key (lower right-hand corner)
•Select 'Delete' in the drop-down menu
•Scroll through the list until the mail application is highlighted:
(The mail application probably starts with the letters 'MM...' [MultiMail]. And it could be 'VersaMail')
•Tap the 'Delete' button at the bottom of the screen
This procedure will delete the mail application and it will be archived on you computer during the next hotsync. If you get stuck doing this procedure, here's a link to the Palm Centro User Guide which can be quite helpfu:
http://www.palm.com/us/support/handbooks/centro/centrorow_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | AT&T Palm Centro Cell Phone - White
Palm treo 500 freezes every time I type SMS.
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Aug 13, 2009 | Palm Treo 500 Centro
I cant use any other sim card on palm centro phone which is unlocked one. i can use airtel india with internet but others are not accepting internet connection
Every operator has its parametre for recieving data or GPRS and 3G (UMTS).Your phone is configured for airtel but if you want to use others their parameters must be entered separately and set as defaul correct one when changing SIM. To find parameters wisit other operators pages, there may be special numbers where you can call and recieve data messages containing parameters and simply save or find instructions how to manually enter them. Also you must activate WAP/GPRS function in every opearator and it winn need aditional charge.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Ihave the palm centro 690 the hot sync screen keeps popping up and freezes everything how do i make it stop? HELP!!!
Hello shellyrick,
I am not sure the Network you are on, but I am with Sprint. I just recently(an hour ago) got off the phone
with tech support (800) 211-4727, and they said "Since this is a known issue we can replace the phone for
free" I am currently trying to get Documents and Media off the phone w/o a SD Card.(Since it keeps freezing)
If I come up with any solutions I will surely post them here for you all.
Jul 17, 2009 | Palm Silicone Sleeve for Centro 685 and...
Forget my password
Try 0000 if you have not changed it
May 30, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Centro GSM unresponsive at times
My Centro doesn't respond ("freeze") on incoming calls up to 10 times a day. The "answer" button (on the screen) and green "send" button (next to "phone") block and it is impossible to accept the incoming calls. It is necessary to perform a soft reset to solve the problem temporary. Even after hard reset the situation is the same. This is very frustrating for a new device. Sometimes, frequent callibration of the screen from the "Preferences" menue delays the freezing effect. AFAIK the problem is software-related, considering the recovery after reset. Is there any update on the palm support page / forums, related to the problem? I couldn't find any. From time to time, there is onother problem I experienced - from the contact menu it is difficult to dial the selected number. Sometimes it is necessary to press “dial” several times resulting in significant delay.
Mar 19, 2008 | Palm Treo 500 Centro
Palm Treo 500 Centro Logo
845 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
