1999 Buick Century Logo
Posted on Mar 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset the coolant sensor - 1999 Buick Century
Anonymous
Level 3:
  • Master 937 Answers
  • Posted on Mar 21, 2013
Anonymous
Master
Level 3:
Answers
937
Questions
78
Helped
240074
Points
2950
There are 2 different procedures used to reset PCMs; depending on whether the vehicle has the older OBD1 emission control system; or whether it has the OBDII system. With the older OBD1 system; the PCM could be reset by disconnecting the battery for several minutes. But the later model OBDII system cannot be reset that way. It requires connecting an OBDII compatible code scanner to the vehicle, and using the scanner to reset the PCM. --------------------------------------------------------------------------------------
FGtech V53
How to reset low coolant light sensor for a 2001 chevy lumina??
There isn't a reset for it. If the coolant is full, replace the sensor.
2helpful
2answers
Mazda 02 coolant sensor
Try resetting the computer.If that does'nt work replace the sensor.
Buick 1991 Regal. It starts fine...idles normallally...but when I start driving, as soon as I come to a stop, it dies.???
First if you did not reset the computer after you replaced the throttle position sensor then do so and if that fixed the problem.If it did not help then replace the coolant temperture sensor and the coolant level sensor then reset the computer.If you replace any sensor you have to reset the computer or the computer will not reconize it as being new and won't reset the perimeters for that sensor.
1helpful
2answers
Coolant light and already added coolant
give the senson on the side of the coolant bottle few taps with a stick or whatever the sensor stickes in cavaliers
4helpful
Reseting coolant light
The only way to "Reset" your coolant light is to fill your coolant to the proper level. If the coolant is at the proper level and the light is still on, then you have a malfunctioning coolant level sensor.
4helpful
3answers
Low coolant light won't go off, coolant level is just fine, how do I reset the light?
is possible your sensor inside your reservoir you need to check
1996 Jeep Cherokee coolant sensor bad
This trouble is common in this models, I have one '93 ZJ and my signal Sensor Coolant Level also is ON for long time; first, try to clean the plug and reset the ECU. If the signal show again, maybe you need replace this sensor.
For more details about location and diagnotics, check this documents:
ZJ-Secc-8D-Ignition-Systems
- Page 5 Location (Coolant Temperature Sensor)
- Page 11 Diagnostics/Service Procedures
- Page 24 Removal Components
ZJ-Secc-7-Cooling-System
- Page 23 Coolant Reserve Tank (Coolant Sensor Level)
I hope help you with this (remember rated this help) Good luck.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
