Question about Vizio GV42L 42 in. LCD Television
Picture but no sound
I have sound but no picture have sound picture flickers tries to work then no picture still have sound?
  • 6 more comments
  • ham solo Feb 28, 2009
    we had tv diagnosed and they said it was the main board needed replaced. other sites say inverter suspect.what say you?
    i checked parts.com 110.00 the tv is a 865.00 piece of ****. 90 day refurb. if it sounds like main board to you, is the install technical or is it something i can perform? or special tools, or can i use you guys to walk me through it?
    can it be the inverter if i can see light at all 4 vents at rear of tv even without video and the main board is 110.00 @ parts direct, see previous install query.can i install?
    does anyone have any advice for me regarding installation. level 1 hardest, to level 5 easiest.
    already tried this method as well as 30 sec. hard restart. Installation?
    CAN ANYBODY ELSE HELP?
    did that to. all i need is someone who can tell me the level of difficulty with self install of the main board and any additional recalibrating, or setup?
    install advice,PLEASE!
    Sergeant:
  • 319 Answers
Main board is shot, my suggestion is to buy a new set. Im sorry its not a very quick fix...
Posted on Feb 28, 2009
  • Patrick Cowan
    Patrick Cowan Feb 28, 2009
    self install wouldnt be hard as long as you realize where all the connections meet other components, and if soldering is required (im not sure on this particular model) you will need a steady hand and plenty of light. ultimately its up to you, but my advice is to replace the set. I have a vizio myself, and have had certain problems with the tuner. I wouldnt recommend this brand for a replacement.
  • Patrick Cowan
    ALSO, if you attempt this repair, make sure the TV is unplugged for a few hours, just to make sure that the capacitors have discharged, otherwise you risk static discharge, or a nice jolt to yourself!!!
    Brigadier General:
  • 3,614 Answers
DO unplugging your TV for 8hours.
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend if the TV wont display the screen only the sound. try to check the connection of the antenna. then try to reprogram the TV with its channel and try to load it.these will help you about the problem so just try it. good luck.hope i helped you.
    Genius:
  • 1,550 Answers
It tends to be the problem of main board fault . You can get one from the link below .
Click this link to order parts
Hope this helps .
  • SAM ANDERSON Feb 28, 2009
    The installation part is bit hard .
    Leave to tv technican to do the installation work .
    Scholar:
  • 85 Answers
Inverter board (which drives the lamps) shut off after a few seconds that makes the picture problem
its the problem of inverter board but that board is not available with the company nor online with any other online websites.as the cost of new tv will be near to same .
Boards are also available from tigerdirect.com. The inverter board is over $300 and the power board about $105. The main board is over $400.
instead of replacing the inverter board its advisable to get the new tv with a full warranty and great feutres and all new parts again.
thanks.
please do rate the solution.
    Sergeant:
  • 326 Answers
Its the main board.you can get the main board at www.partstore.com but its a costly issue to get it.getting new tv is also advisable in such case.hence the option is yours.to get the board or the tv.as the problem is started it can blow something else later or now. if the tv is very old get the another tv.
    Scholar:
  • 165 Answers
Either the display ic on the board is faulty or is loosened .repairs needed.
  • mradviser Feb 28, 2009
    its the main board
    rate the solution accordingly
    President:
  • 990 Answers
Hello sir; Let me try may be it work, I believe your TV connect with control box, If not forget about it,if yes, then unplug the control box and TV shoul be off too, one minute later plug in power, until time clock display then turn on the control box TV should back to work now.
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Darker picture and high pitched sound from back of tv. Also flickers.
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Televison & Video
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
My LG Lcd tv takes a minute or so to turn on then sometimes the picture flickers and goes out. The tv is on but no picture or sound. When I try to use the menu button on the tv it doesn't work. Whe
The fact that you have no menu or onscreen display, leads me to believe that it is the main logic board. Either the processor ic or the voltages going to the main board are missing. Check to see if the main board is getting 5v and 3.3v to determine if it is your power supply not supplying the voltages or your main board.
Oct 26, 2011 | LG 42LC2D 42 in. LCD HDTV
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Dec 31, 2009 | HP PL4260N 42 in. Plasma HDTV
No picture when turned on - sound ok
I think that you should try playing around with some of the plugs
Jun 21, 2009 | LG 26LC2D 26 in. LCD Television
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Vizio GV42L 42 in. LCD Television Logo
106 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
