Question about Toyota Vehicle Parts & Accessories
1994 camry won't keep running
I have a 94 camry that starts and runs good until you press the brake to put it in gear, then it dies and loses all power. there is a security light that flashes when you turn the key on. is it a security problem? thanks
  • mylrhg1957 Feb 28, 2009
    i really don't know if it has an autostart. are you talking about a remote starting switch?
  • 40 Answers
Does the car have an auto start, if so this could be the problem, like a possible malfunction. And yes it would be a security problem. With auto starts there is a small switch installed so you can turn it off, or reset it. Maybe try and find the switch and turn it off. If the problem stops and you can drive it i would look at replacing or repairing the auto start
Posted on Feb 28, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Voltage regulator
Sounds like a bad connection. The alternator only charges the battery, so if it or the voltage regulator in the alternator fails, the battery would slowly run down, not die all at once.
Jul 18, 2013 | 1994 Buick LeSabre
1985 toyota camry unplug mass air flow sensor engine will start plug back in engine dies
There is a switch in the airflow meter that keeps the fuel pump relay closed as long as there is airflow. With the meter unplugged, the pump should not run except when the key is turned to start. It would seem to me that you have a wiring issue. Try jumping the fuel pump relay so the pump runs whenever the key is on. (Remove the relay and jump the pump wire to the accessory wire--see top left diagram.) This defeats the safety feature but will keep the pump running.
Oct 30, 2017 | 1993 Toyota Camry V6
Dies when put into gear
Have you checked fuel pressure yet ?
Dec 05, 2012 | 1994 GMC Sierra
I changed the 02 Sensors on my 03 Mitsubishi Galant do I need to reset anything on my car? It turns on fine but idles low when put in gear and shuts off.
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Nov 28, 2012 | 2003 Mitsubishi Galant
I have a 1999 Toyota Camry it starts up and runs for a few seconds and dies right down. I've changed the fuel filter and it seems to run just a little bit longer. But it still will not keep running. A
Check your fuel pressure. It may be low, or losing pressure from a bad pressure regulator. A thorough test of your fuel system seems in order. (A pressure test can also detect a bad regulator, if it's done properly.)
Nov 12, 2011 | 1999 Toyota Camry
My car dies when it get warm?
sounds like a your tie rod ends or ball joints are bad. as far as it turning off in gear means that the fuel injection is screwed up which means its a gas problem which is a intake problem with wrong fuel mixture or even a vacuum leak.
Jul 26, 2009 | 1994 Pontiac Grand Am
94 toyota camry running really rough
1st to do,replace fuel and air filter, spark plugs.
Jul 21, 2009 | 1994 Toyota Camry
Vehicle Parts & Accessories Logo
130 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
