Question about Panasonic NN-S254WF Microwave Oven
The light under the oven that lights up the stove top cannot be shut off...the button on the keypad works(sounds off) and the lights dim slightly but the control will not shut them off...Had to remove bulbs till I can solve the problem Panasonic NN-S254WF...Thankyou for your time......Wes
  • Panasonic Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
If you wait too long for the repair, other parts can short, destroying the microprocessor (as shown in the second photo) and rendering the oven dead.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Mar 02, 2009
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Oct 01, 2014 | Panasonic Genius Prestige Nn-Cd989s -...
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Stove Light
try to fine the light switch in door and check the bulb
Sep 18, 2007 | Whirlpool MH7155XM Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Stopped working, Display reads all 8's
It sounds like a shorted keypad. This can be due to age/wear or due to moisture. If the unit is sevewral years old or has ben used a lot, then age and wear can be suspected. Moisture is most often due to spraying cleaner directly on the keypad, which allows it to leak into the works. Always spray your cleaner on a soft cloth and then wipe the keypad clean. Moisture can also get in if the microwave is mounted above a stove and a lot of boiling is done without adequate ventilation, usually via the exhaust or hood fan. This fan should be on when cooking on the range top. In some cases, there may be some deposits on the keypad strip where it goes into the connector on the control circuit board. Sometimes that can be cleaned by unplugging then replugging the strip. Could it be that you're not setting the manual according to the instructions in the owner's manual? The manual is olnine at http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf I have attached a scren shot from the manual which shows the clock setting procedure. Maybe it's as simple as this.
Oct 14, 2006 | Samsung MW1030WA Microwave Oven
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Panasonic NN-S254WF Microwave Oven Logo
129 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
