Question about Sport & Outdoor - Others
My Hot Springs spa is making a strange noise
We haven't used it recently and I probably need to clean the filters but it is hard to do that when it is too cold to be outside spraying the hose on the filters. What should I do? Do I need to call a repairman?
Atleast clean the filters the best you can in the sink, where is the noise coming from? JJ
Posted on Mar 13, 2009
Leisure rite spa has fault code f2
The F2 Error Code is usually from a Balboa sp pack / system and normally is referring to a flow issue in your hot tub.
The usual culprit is a dirty filter, so make sure to either replace or give your hot tub filter a good cleaning. Also look at your intakes and out takes and make sure they are clear of debris.
We have a filter cleaning guide located here:
http://bathandspaparts.com/filtercartridgecleaning.aspx
You should also first cut the power to the unit and let it cool down and then reset it.
If this doesn't clear the problem up, you are probably going to need to start looking at water flow restrictions, such as air bubbles in the piping. A good flush will usually clear all of that out, without having to crack open any of the plumbing.
Last but not least, if none of that works, you are going to need to start looking at fuses, heating element, or the circuit board if all other trouble shooting does not fix your error.
The best advice here is that if cleaning or replacing the filter doesn't solve it, and then flushing out the system doesn't work, call a spa tech and have them come out. Unless you are a qualified spa tech, messing with the heater or circuit board is usually not advised.
Hope that helps.
Mark
Bath & Spa Parts Online
http://www.bathandspaparts.com
Jul 19, 2016 | Pool & Spa
Black water pours out of the heater system into intex spa
Backwash filter system, change filter media if over two years old, flush out heater. Check water clarity going into the filter system, if dirty..., you may have a broken underground line. Check water clarity coming out of filter system, if dirty.., backwash again and check filter media. Also, Heater boiler headers may be rotting.
Apr 10, 2016 | Intex Pool & Spa
Do scumbugs work?
Check out enzymes, such as Spa Perfect (by Natural Chemistry). This is a liquid that eliminates oils from the water. It is basically the stuff they cleaned up the Valdez oil spill with in Alaska. I believe it is more effectine than sponges. 25343440-0qsqf4jb4mxxsbf01smpiwyc-2-0.jpg
Dec 28, 2014 | Pool & Spa
I have brown gunk sticking to the walls appearing to come from the pipes in my Spa
You have one of four possible issues in your hot tub.
  1. Mold
  2. Algae
  3. Hard water
  4. Calcium
The first thing you want to establish is if the problem is organic or non-organic, because the solution to the issue is different for both. If it is organic mold or algae then you need to drain clean and sanitize everything, tub, filter, hot tub cover etc.. and it may take more then one refilling depending on what it is. You could try and take a sample in a clear jar and put bleach in the jar. If the substance in the water disappears you know its organic.
If the issue is water hardness or calcium then you will need the corresponding chemicals to deal with these issue. We have a chemical called spa control that deals with water hardness. You may also want to use a a pre-filter when filling your hot tub to rid yourself of high content minerals in your water.
Hot Tubs Chemicals to Keep Your Hot Tub Clean
I have a fairly large Hot Springs spa with 5 reusable filters. I keep it pretty clean but was considering adding something to help keep oils under control. I see several alternatives on the market:
the oil is from the body and will be impossible to control. any additive you use may cause irritation to the users. Spa baths are very bad for spreading disease ( hotels with spas have to empty and clean the spa after every person staying there by law)
they can be cleaned in home use by using a detergent on a rag and cleaning around the water line. there are reusable filters on the market that you can clean in detergent and rinse out to save the cost of filters.
Dec 27, 2014 | Cars & Trucks
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
My 1999 Toyota camry makes a rattling noise when in reverse and mostly on inclines. it does not make the noise in the winter but it does when its hot out. Sounds almost as if its coming from transmiss
even with the car a noise can be hard to find.does ti go away with rpms or stay.does motor vibrate hard when this occurs,you need to have a tech ride with you and try to point out noise so can be found .you can ck for loose heat shields and engine trans mounts. the trans car needs to be on drive up rack to ck trans out.
Aug 05, 2012 | 1999 Toyota Camry
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
Cant remove the filter grate from jetsetter spa
Ok, I can sort of solve this... According to the local hot springs dealer, there is a special tool you need to open the grate, however, they cannot seem to to locate one for sale. The part number no longer shows up in their system, so I am screwed with the same situation :(
Mar 26, 2009 | Pool & Spa
Sport & Outdoor - Others Logo
168 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
