Question about Sony Mavica MVC-CD350 Digital Camera
Cover open warning started coming on. How do i troubleshoot?
  • 3 Answers
Try to find the switch of cover closing, it is on on the cover from inside - small and thin, when You press it, the camera thinks it is closed.
if it doesnt work ordinary try to clean it .
Posted on Jan 04, 2010
My golf 1.6 warning door light ,,it jumps from rear to driverside to leftpassenger side etc also boot warning light comes on when i sart and driving car ..any ideas ..robbie
Most likely you have corrosion problems. Pull the plug/s at the BCM. look for a white to greenish color. Clean it as best as possible. If the BCM is at a place that has water issues(under A/C plenums). Cover it with plastic. You may need to open the BCM cover and clean the board also.
Jun 07, 2015 | Cars & Trucks
The od light comes on the the transmission temp warning comes on in my 2000 dodge durango
Check transmission fluid level. Is there a manual Overdrive engagement button? If so you probably have a worn out wire from the switch to overdrive solenoid. I had a similar problem different car. Solution was the "spiral plastic" wire cover to cover the opening on the control wire and easy to get on the wire without having to cut and rejoin wires. Was supposed to be temporary but has lasted about 5 years. This may also be the issue with the Temp warning light. The wires may be parallel to each other. Hope this helps, good luck.
Mar 12, 2015 | 2000 Dodge Durango
The cover open signal comes on when the printer is turned on even tho the cover is securely closed. Can I bypass this cover open warning as the printer works when this light is not on.
Find where the switch that detects if the cover is open or closed is. Once you find it see if it is stuck in a position that tells the printer it's open. If for some reason it is broken, try placing an object that will press down the switch and tell the printer it's closed.
Mar 01, 2011 | Epson Stylus 1520 InkJet Color Printer
Low ink warning not right. ink is full. What to correct warning?
According to the information on the website, you should be able to press the Stop/Reset switch for about 5 seconds to disable ink level monitoring on the empty cartridge.
Feb 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
1. Toner cartridge & drum warnings on, print fine. How reset?
Drum light reset:
Open front cover. Hold down button located under LED's until all LED's are lit. Release button and make sure drum LED is off, then close cover.
Dec 22, 2009 | Brother HL 1440 Laser Printer
Took cover off; replaced; can't get warning light to shut off.
check carefully around perimeter of cover, there should be a switch that is either broken or not being engaged.
Aug 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
May 23, 2008 | Olympus Stylus 790SW Digital Camera
Side cover open
yes there is a cover switch, but if this is a new printer, changed it under warranty, but if this problem occurred now you have to find a problem, why this door won't close correctly. the cover switch is located on the left side if the cover
Apr 10, 2008 | Konica Minolta magicolor 5430 DL Laser...
No workie
Brocken sensor or catch on the cover Check the cover and see that there is a catch that goes into hole- it has probably broken off and therefore not making contact. If so thry a match stick or similar into the hole TThis will [hoepfully put the warning out even if the cover is open. If so leave it at that. If not a repair shop job- but warned big bucks just to look and parts may not be available
Jun 11, 2007 | Olympus Camedia D-40 Zoom Digital Camera
Sony Mavica MVC-CD350 Digital Camera Logo
146 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
