Question about RCA DRC310N DVD Player
I cannot get a disc out of the DVD player and have followed the troubleshooting directions in the manual....tried to unock it, and tried push stop+eject at the same time....but still didn't work.
  • bbastable Feb 28, 2009
    Thanks- the DVD is out!
  • 76 Answers
Unplug it, take the cover off, and try removing the DVD manually.
Posted on Feb 28, 2009
How do I play a simple disc or blu-ray disc?
Tell me this: do you have an owners manual. How have you connected your player to the TV (in detail please). I specialize in simple answers.
Jun 04, 2013 | Samsung BD-E5400 - Blu-ray disc player
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Zenith ZND400 DVD/VCD/CD PLAYER
its a mechanical problem from the disc tray section.The disc tray dosnt lap well inside,call your tecnician he will know what to do.
Jan 08, 2008 | Zenith XBV442 DVD Player/VCR
RCA DRC310N DVD Player Logo
170 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
