My buttons on my 2005 honda accord 4 cylinder car wont work
When i press any of my buttons on the key nothing happens when i press the lock button it doesnt lock when i press the unlock buttton it doesnt unlock when i press the trunk button the trunk wont open and even the panic button doesnt work anymore I dont whats going on
Re: My buttons on my 2005 honda accord 4 cylinder car...
I assume this is the only remote you have? If not does the other have the same result? Have you changed the battery in the remote? If yes, is it installed with the right polarization?
? 10:49
https://www.youtube.com/watch?v=T01989YN2Ew
Jan 20, 2013 - Uploaded by Flip Keys
Learn to repair all types of Honda Steering Lock. Either wi... ... I am in NJ and dealing with a key that will sometimes not turn in the ignition cylinder on a 2005 Honda Element. .... (2006 honda accord ) .... It won't turn or come out. ... When you put the rightkey in the slot (and through the key reader part of the ...
If release lever is not functional, use key. If key will not turn in cylinder, spray WD-40 into cylinder and use sawing motion to get key inserted and continue sawing motion to free up lock wafers internal to cylinder so it will turn with key. If this process is not effective, you will need to remove rear seat to access paneling to trunk lock and open accordinly
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
Turn the ignition on
Press Lock/Unlock within 4 seconds
Turn ignition off and hen back on within 8 seconds
Repeat steps 2-3 two times
Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
Switch ignition off and then remove the key
Civic 1996-1998
Turn ignition on
Press and hold the valet button which is situated on the radio within 5 seconds.
System should now lock and unlock the vehicle indicating it is in the programming mode
Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
Release valet key
Radio remotes 2 and 3 button types
Switch ignition on and repeat for 3 times.
Press he lock button, switch the ignition off and back on and then press lock button again.
System should now lock or unlock
Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
Programming When Remote control added or replaced. System malfunction. How Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
ok bare with me read carefully you need to program the new transmitter to your car. 1 turn igntion switch on (ii)second position 2 within 1 to 4 secs press the transmitter lock or unlock button with amied at the keyless receiver in the power master switch 3 repeat steps 1 and 2 3 times 7 confirm you hear the sound of door lock actuators working then press press lock or unlock button again or code won't be stored 8 within 10secs if you have other transmitters press unlock of each one each time the doors locks and unlocks with operate 9 turn off ignition then there you go try them out
Programming When Key added or replaced. System malfunction. How Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys. NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Press the passenger side door lock button. if the driver side door unlocks now but wont unlock when you hit the driver side door lock button, it is usually a network communication problem with the B CAN or a faulty Body Control Module.
Want to programs the remote key of your Honda cars, then you must reprogram all of the key-less remotes of your Honda Accord once you are in the programming mode. You must complete each step quickly so to prevent the system from exiting the programming mode.
Note: Maximum Three remote transmitters can be programmed.
Make sure all the doors are UNLOCKED before starting this programming procedure.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNLOCK button on one of the remotes. (An unprogrammed remote can be used for this step.)
3. Turn ignition switch to ACCESSORY (I) or LOCK (O)
4. Turn ignition switch to ON (II)
5. Press the LOCK or UNLOCK button on one of the remotes.
6. Turn ignition switch to ACCESSORY (I) or LOCK (O)
7. Turn ignition switch to ON (II)
8. Press the LOCK or UNLOCK button on one of the remotes.
9. Turn ignition switch to ACCESSORY (I) or LOCK (O)
10. Turn ignition switch to ON (II)
11. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
12.Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
13.Turn the ignition switch to LOCK (O) to exit programming mode.
14. Test remote(s)
For more clarification, i have also shared the video to do this process, Have a look
