Question about Kenmore 46462 Front Load Washer
Front load Kemore washer-water won't shut off
Water won't shut off
  • 106 Answers
Your inlet valve is defective, approach dealer with model number, you can replace it yourself.
Posted on Feb 28, 2009
  • fixer444 Feb 28, 2009
    Or you can try these sites for spares: (which is good)
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
I have a kemore elite he 3t front load washer it won't drain and its giving me a F02 error message. what does this mean? Help!
it's a long drain error code,most likely the pump is blocked with all kinds of good stuff,coins, screws,and who knows what else,vac out all the water with a shop vac, and next time open the door,look around the opening where you put the clothes into the washer and you'll see a tag with the model and serial numbers,just need the model number,remove the bottom panel,look at the pump,if the center part can be removed,turn it slowly counter clockwise until the water starts to leak out and stop and vac up the water as it leaks out,do this until it's empty and then remove the center catch piece of the pump and clean it out,stick your finger in the pump and make sure nothing is stuck in the impellar,also check the rubber boot part of the hose,sometimes stuff is still in there,if the center of the pump doesn't come out,pull off the hoses to the pump and check them for junk in them and check the pump,reconnect the hoses,fill with some water and put in a spin cycle,if the water still doesn't drain out most likely you'll have to change out the pump.
Aug 16, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kemore washer will not spin
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Jun 19, 2009 | Washing Machines
Kenmore front loading washer leaks
under the front panel ther should be techshet/ trouble shooting guide. and withthe front panelremoved perhaps you can see ewhere the leak is coming from
Mar 01, 2009 | Kenmore HE2 Plus Front Load Washer
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
