Question about Grundig S350 AM/FM/SW Radio
Grundig S350DL needs a am aerial to bring in the
Our Grundig S350DL needs a am aerial to bring in the stations clearly, any suggestions as to where to find one in Ontario.
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Posted on May 08, 2009
Grundig gu37fhd1080
Hi Bill
It sounds like a fault with its main system control memory IC. Please contact any service technician, to confirm it. In most cases, this component might need replacement. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
Aug 10, 2011 | Grundig S350DLB FM Radio
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
My radio won't stay locked onto a station. When I push a pre programmed station like 107.3 it plays for a little while than randomly switches to 107.1 or 107.5.....and goes back and forth every few...
i have a funny feeling its the aerial but it could also be a faulty chip within the set itself i have had customers complaining of this before with certain makes of radio ,never get it with a grundig or bleupoint though
Mar 22, 2011 | 2003 Pontiac Montana
Have a new digital TV, can only record the 5 terrestial channels, how do I tune in to the other digital channels, i.e. BBC3, E4 etc.
It's not clear what you mean! So one of these answer might solve it. If you are talking VCR recording it must either have a freeview tuner or have a freeview box connected to it via a scart. Otherwise it will only record the five terrestial.
Digital TV -you must have a good aerial otherwise you will not pick up all the stations. If it has a hard disc drive the same will apply.
If the terrestial stations have any grain or the picture is not as clear as a bell on all, then your aerial will not be good enough. The type of aerial should be for freeview. See image below also you need to have CT100 cable (the stuff used for satellite) not the old brown co-axial cable (see below).
Jun 05, 2010 | Televison & Video
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Grundig S350DL shuts itself off
The default mode for this radio is in "sleep-timer." You can adjust the time it stays on or you can hold the On/Off button down for a few seconds as you turn it on. (You'll notice the "bed" icon no longer appears.)
Nov 30, 2008 | Audio Players & Recorders
Intermittent volume level
Radio Shack does provide a volume control cleaner that you could gently spray to clean the contacts, but you may simply have a defective knob. (The first S350DL I bought had a defective volume control.) Don't hesitate to call Eton Customer Service either.
I hate to say this, but I've become a little wary of buying radios at Radio Shack. I have a suspicion that occasionaly radios that are returned get "recycled" back into stock rather than sent back to the manufacturer. I had to return 2 radios directly to Eton / Grundig after getting back to back defectives at RS.
Oct 21, 2008 | Grundig S350 AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
418 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
