Question about Canon PIXMA MP180 All-In-One InkJet Printer
CANON PIXMA MP180/MP160 PRINTER ERROR CODE E3 FOR PAPER JAM THERE IS NO PAPER JAM Can you give the solution about this problem? please share yout Idia...The problem of MP180 is paperjam i am repetedly to look the printer becuase of paperjam problem. But i cant see the paper in the printer...
  • 4,041 Answers
Hello There please try it may clean it up for you There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Paper feed problem, error 3
E3 means paper jam,you need to unzip the printer to look at the paper sensor,not be skipped or broken.If i have been useful please give me a vote :).Thanks
Mar 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper and displays error code E3... have tried cleaning the feed mechanism as per the owners manual but problem persists
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-20
Aug 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
544 people viewed this question
old marine
old marine
