Question about MSI K8MM-ILSR Motherboard
Cas latency in AMI BIOS 3.31a
Hello everyone,
I try to setup the cas latency of my RAM memory in AMI BIOS but I can't. I know that it is under the Advanced Chipset Features menu but I don't see anything about Cas Latency. In my Advanced Chipset Features menu, I have tose settings:
LDT to AGP Lokar (upstream) "16bit"
LDT to AGP Width (downstream) "16bit"
LDT to AGP Lokar frenquency "800Mhz"
Memclock mode "auto"
Memclock value "DDR333"
bank interleaving "auto"
Node interleaving "disabled"
bust length "8 beat"
Vlink 8 x supported "disabled
AGP mode "auto"
AGP fast wright "enebled"
AGP apperture suze "128MB"
OnChip VGA Frame buffer size "64MB"
CPU Direct access onchip VGA FB "disabled"
Boot Device select "CRT"
I know that Cas Latency is set to 3 because I can see it at startup. I would like to change it to 2.5.
Thank you
5 Suggested Answers
jell587
  • 447 Answers
SOURCE: Try to install 2gb PC2700/DDR333 memory on MS-6741 motherboard
Hey Luc,
I got a chance to check on that memory part number. Most of the sources that I ran across were outside of the USA (and there were very few of them). Was this memory purchased from an online vendor or over the counter at a brick and mortar store?
Here's the thing - I can't find any listings for this memory module on ebay which is odd because generally you can find anything by punching its part number into ebay and a lot of the time you get more detailed specs on the part thru ebay than you would thru a regular web search. I did determine that the specs you posted were pretty much right but I couldn't get any more advanced specs than what you provided.
You may want to source a diffrent module(s) for your unit using the specs I posted a link to before and going with the PC3200 mods. Just make sure you match the CL and voltage detailed for your machine.
I wish there was a better answer for you but if I can't verify the validity of the memory you're trying to use than I have to recommend going with a different module altogether.
Post back here with your progress on this, I'll be curious to see how it turns out.
Posted on Feb 27, 2009
  • 3 Answers
SOURCE: Radeon 9550 + AGP issues on MSI KT4V
First of all, why do you bother to change all these spec? Secondly, since your screen flicked, I would suggest you just leave them like that. Your PC is just as old as mine, don't mess around with it too much.
Posted on Jun 23, 2009
  • 71 Answers
SOURCE: computer starts up then shuts off
make shure all cards are pushed in al the way and check memory too
Posted on Feb 18, 2010
pcsyke
  • 152 Answers
SOURCE: I am using a 848P-A
1. Does your new SATA hard drive can be seen in BIOS or POST. if yes 2. Does this new drive shown in "my computer" it should be no or under device manager is should be yes. 3. Use disk management.
To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
To create a new partition or logical drive on a basic disk:
  1. In the Disk Management window, complete one of the following procedures, and then continue to step 2:
    • To create a new partition, right-click unallocated space on the basic disk where you want to create the partition, and then click New Partition.
    • To create a new logical drive in an extended partition, right-click free space on an extended partition where you want to create the logical drive, and then click New Logical Drive.
  2. In the New Partition Wizard, click Next.
  3. Click the type of partition that you want to create (either Primary partition, Extended partition, or Logical drive), and then click Next.
  4. Specify the size of the partition in the Partition size in MB box, and then click Next.
  5. Decide whether to manually assign a drive letter, let the system automatically enumerate the drive, or do not assign a drive letter to the new partition or logical drive, and then click Next.
  6. Specify the formatting options you want to use by using one of the following procedures:
    • If you do not want to format the partition, click Do not format this partition, and then click Next.
    • If you want to format the partition, click Format this partition with the following settings, and then complete the following procedure in the Format dialog box:
      1. Type a name for the volume in the Volume label box. This is an optional step.
      2. Click the file system that you want to use in the File system box.
        You can change the disk allocation unit size, and then specify whether to perform a quick format, or enable file and folder compression on NTFS volumes.
      Click Next.
  7. Confirm that the options that selected are correct, and then click Finish.
The new partition or logical drive is created and appears in the appropriate basic disk in the Disk Management window. If you chose to format the volume in step 6, the format process now starts.
To format a partition, logical drive or basic volume:
  1. In the Disk Management window, right-click the partition or logical drive that you want to format (or reformat), and then click Format.
  2. In the Format dialog box, type a name for the volume in the Volume label box. This is an optional step.
  3. Click the file system that you want to use in the File system box. If you want, you can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
  4. Click OK.
  5. Click OK when you are prompted to format the volume. The format process starts.
For further Instructions click the link DISK.
Thanks, looking forward to fix your problem, just give a feedback if this helps.
Posted on Jul 02, 2011
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
Tip
10 reasons why PCs crash-You must know tip 3
3 BIOS settings
Every motherboard is supplied with a range of chipset settings that are decided in the factory. A common way to access these settings is to press the F2 or delete button during the first few seconds of a boot-up.
Once inside the BIOS, great care should be taken. It is a good idea to write down on a piece of paper all the settings that appear on the screen. That way, if you change something and the computer becomes more unstable, you will know what settings to revert to.
A common BIOS error concerns the CAS latency. This refers to the Ram. Older EDO (extended data out) Ram has a CAS latency of 3. Newer SDRam has a CAS latency of 2. Setting the wrong figure can cause the Ram to lock up and freeze the computer's display.
Mcft Windows is better at allocating IRQ numbers than any BIOS. If possible set the IRQ numbers to Auto in the BIOS. This will allow Windows to allocate the IRQ numbers (make sure the BIOS setting for Plug and Play OS is switched to 'yes' to allow Windows to do this.).
on Mar 04, 2010 | Computers & Internet
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Which ram do i need?
You need DDR SDRAM like this,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231039
Best value for the money
Have a nice day!
Aug 31, 2011 | ASUS P4G800-V Motherboard
Can i use a ddr ram in a dell latitude c600 notebook
hi simply NO this is sdram as here are the specs for this laptop Memory Architecture SDRAM Memory module sockets two user accessible SODIMM sockets Memory module capacities and type 64-, 128-, and 256-MB
3.3-V SDRAM SODIMMS 1 Standard RAM 64-MB memory module Maximum RAM 512 MB Memory clock speed 100 MHz Memory access time CL2 or CL3 (Note: CL3 indicates a CAS latency of 3 clocks) BIOS address F000:0000-F000:FFFF
hope this helps
Jan 10, 2011 | Dell Latitude C600 Notebook
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Compatible memory for P4M266A-8233
Hi!
No you can not!
This is what memosticks that mobo of yours supports
DDR 200/266
PC100/133 SDRAM
Max. Memory 4.0GB
Good luck
Nic
Mar 09, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Why does my comp didn't run Dual channel ?
Go into your BIOS and activate dual channel mode.
please also note that several motherboard required you to put the modules in certain slot configuration (such as in slot 1 and 3 or 2 and 4) but if you got only 2 slot then forget about this slot configuration.
Aug 30, 2008 | ASUS P5RD2-VM Motherboard
ADDED NEW RAM NOW MEDION WON'T BOOT UP
hi
i needs to the rams are in same speed. if it not you put a rams in same speed
next you need to study your motherboard manual it supports the ram speed.if ever this is ok. then your ram will be faulty
Mar 19, 2008 | Medion MD-1704 PC Desktop
Memory Issue
You could try lowering the Cas latency. Just boot into the bios and try lowering the cas latency up by .5 For example, if it's running at 2.0 change it to 2.5 or 2.5 to 3.0 Yes this will slow down your system, but it may be a more stable speed for the ram to run at. You could also have bad ram, or maybe your problem isn't ram related at all. It's possible your motherboard is the cause of all of your problems. Peter
Oct 04, 2007 | ASUS P5RD1-VM Motherboard
MSI K8MM-ILSR Motherboard Logo
1,080 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
