Question about JVC DR-DX5 DVD/HDD Recorder
Remote Control Code problem
I have 3 panasonic units 1 Plasma TV and 2 DVD Recorders and the remotes turn each other off when I dont want them to. I changed the remote control code on my new DMR-EX88 unit to DVD 3 and now I cannot get it to work. I tried to reset the unit as per instructions and get to the screen to select my state and cannot go any further. I cannot change or select anything straight from the unit and the remote wont work so I cannot get any further. Can you suggest another way to reset the DVD code back to no 1 or reset the remote somehow.
I read through other problems on the web page and tried them
Finally I got one of them to work
Thanks
Posted on Mar 01, 2009
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Feb 20, 2016 | Panasonic Televison & Video
I am trying to program a new BELL remote control and i need the tv code to control the tv tks
  • 1. Turn on the device you want the remote to control; this can be your television, DVD player, or VCR.
  • 2
    Press and hold the appropriate mode button for the above device, until all the other mode buttons light up.
  • 3
    Hit the blank power button.
  • 4
    Press the up arrow on the remote repeatedly until the device turns off.
  • 5
    Hit the "#" button to lock in the code.
  • Jan 23, 2011 | Panasonic Viera TH-42PX80U Plasma TV
    Power light blinks 13 times
    need replaced A-BOARD
    Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
    After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
    1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
    2. Press the number [2] key on the remote to highlight [SRV-TOOL].
    3. Press the [OK] button on the remote control to select [SRV-TOOL].
    4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
    5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
    6. Press and hold the [RETURN] button on the remote control until the TV turns off.
    7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
    8. Remove AC power.
    Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
    Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
    http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
    http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
    To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
    Hopefully, your manual will display your error codes.
    Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
    Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
    I need code for samsung remote code for tv
    Automatic Programming
    1. Turn off the device with which you want to use the remote control.
    2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
    3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
    4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
    5. When the device turns on, press ok to store the code.
    Dec 15, 2009 | Brookstone 538744 Remote Control
    Remote control code
    1. Press tv on your Sky remote control.
    2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
    3. Press tv again
    Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
    Panasonic Code: 0051
    4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
    5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
    Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
    Pairing Sky+ Remote with Panasonic Viera remote
    3. Press tv again
    Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
    I need the region dvd code for my panasonic triple play tv
    1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
    3. Press the 7 button on your remote control
    4. Press the 5 button on your remote control
    5. Press the 3 button on your remote control
    6. Press the 8 button on your remote control
    7. The currently selected region will be indicated on the TV.
    8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
    9. Press the Menu button on your remote control
    10. Press the Menu button on your remote control
    Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
    Nov 11, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
    Panasonic DMR ES10
    1) Check your batteries.
    2) Check the manual
    3) Check online if you no longer have one
    4) It may be necessary to replace the remote
    Aug 15, 2008 | Panasonic DMR-ES10 DVD Recorder
    Romote control not working
    1. The owner's manual is available online:
    http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
    Download the manual under Operating Instructions.
    2. To remedy "SET1" problem, Press 1 & Enter at the same time.
    Hope this helps
    Aug 10, 2008 | Panasonic DMR-ES35VS
    JVC DR-DX5 DVD/HDD Recorder Logo
    177 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
