Question about Maytag CWE4800A Electric Single Oven
Maytag electri single oven, not getting hot enough?
Electric rods not getting not coming on, sometimes only the top rod comes on?
Replace the lower element. easy fix. TURN OFF POWER. remove two screws inside that hold element in place. Pull forward. disconnect clips that connect wire to element. reverse steps to replace with new element.
Posted on Mar 17, 2009
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
F2 appears on the front panel and there is a fan that is running and won't turn off. What should I do?
F2 Oven too hot Check oven temperature sensor
The problem is either with the sensor or the wire between the sensor and the control panel.
The sensor is the metal rod that is inside your oven, it comes in on the back wall and is a little smaller than a pencil
Jun 28, 2011 | Magic Chef 9815 Electric Single Oven
Oven door is locked shut. Latch for self cleaning won't fully open. Thanks
FIRST TRY TO TURN THE BREAKER OFF FOR ABOUT 20 MINUTES, IF THAT DOESNT WORK YOU WILL NEED TO PULL IT OUT AND REMOVE THE BACK PANEL ( UNPLUG IT BEFORE YOU WORK ON IT) THEN LOCATE THE DOOR LOCK MOTOR AND ROD, SOMETIMES THE ROD NEEDS ADJUSTING, SOMETIME THE MICRO SWITCH ON THE MOTOR GOES OUT,, YOU CAN GET IT ULOCKED AND STILL USE IT, BUT YOU WONT BE ABLE TO USE THE SELF CLEANE,, YOU WILL HAVE TO FIND OUT IF IT IS THE MICRO SWITCH OR THE MOTOR AND RELACE THE PART BEFORE YOU CAN USE THE SELF CLEAN
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
Kenmore 790.75738892 won't heat up enough or fast enough what can I do to fix the problem?
most likely justneed a temp sensor. there is a rod that comes through back of oven. you will find it inside oven on back wall.
Aug 01, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
No heat to the oven
if the heating element "rod" doesn't turn orange (hot) when it's on it's bad so; remove the heating element and get a new one from an appliance parts site on the web and install it don't forget to unplug the range first!
Apr 20, 2009 | Vulcan ECO2D Electric Single Oven
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Range is shuting off
wen it became hot the water content from air turned it off.
Jan 02, 2009 | Maytag 30" Built-In Single Electric Wall...
MY OVENS FAN KEEPS BLOWING AND I CANT DO ANYTHING ON IT PLUS IT KEEPS SHOWING F3
This code is usually an oven sensor that is telling the control that the oven is too hot, This is why the fan stays on. Try replacing oven sensor. This is the steel rod on inside oven in back wall at top left or right. Even though you can usually unscrew from front, it often won't come out far enough to unplug it from harness. If it does, be sure you get plug back through both walls of oven, or it will melt. Use end of small screwdriver stuck in the connector to guide through back wall. If doesn't come out you mist pull oven out if wall and access from rear.
Nov 20, 2007 | Whirlpool AKZ159IX Oven
F3 and F5 signals
could be a probe thats that brass looking rod you see when you open the oven f3 is oven probe code it controls the temp some of them you can take the two screws out on the in side and pull the probe out far enough to get to the connector to change some you have to pull the oven
Sep 10, 2007 | GE JKP15 Electric Single Oven
Maytag CWE4800A Electric Single Oven Logo
177 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
