Question about Toshiba Satellite A205-S4617 Notebook
Cant find the toggle switch for wireless on my toshiba laptop. f8 and fn not working
  • ajeenahantho Feb 28, 2009
    Thank you sooooo much. The switch didn't look exactly like it,but it was in the same spot. It was a little silver circle that was flush with the computer. Thank you again!!!
  • 2,653 Answers
Should be right in the front according to this picture.
Posted on Feb 28, 2009
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    No prob. Thanks for not forgeting to rate!
How do I turn on wireless capability
To enable or disable wireless functions, you must use the Hot Key combination of "Fn" + "F8". This means to press and hold the "Fn" key (near the windows key), and the press the "F8". This is a toggling function. Each time you press the key, it will turn on or turn off the function. Look for the Wireless Light to ensure that the wireless activated.
Feb 26, 2015 | Toshiba Satellite L645D-S4056 laptop
Wirless switch for toshiba c660
go and get the manual at
Apr 18, 2012 | Toshiba satellite c660
How do I turn off wireless radio?
There are a couple of ways to turn off the wireless. 1) Look for a wireless switch on either side of your laptop or at the front of your laptop. 2) Normally the FN (Function Key) + (F1 thru F8) will toggle the wireless between on and off. To find the correct F1 thru F8 key to hit look for the )))) symbol which denotes wireless. Press and hold the FN key then hit the Function key that corresponds to wireless. Watch your desktop screen because most will display Wireless On or Wireless Off as you hit the keys. If not one sure way to know it is off is look at the computer at the bottom right of the screen near the time, it should go from being a solid green to a computer with a red X on it.
Mar 20, 2012 | Toshiba 156 Satellite P755S5265 Intel Core...
Wifi is on, but the laptop says it isn't and won't show connect points available. What's up with that?
1. Make sure it is not disabled in device manager.
2. Make sure the WIFI switch is toggled to on
3. Hold down FN + F8 key to toggle wireless on/off
Let me know if any of the above works.
Best regards,
embraced support
Sep 05, 2011 | Toshiba Satellite E105-S1402 Notebook
Wireless communication switch is disabled. I am not able turn on wireless communication switch. I was wondering if Toshiba a135-s4527 has a built wireless hardware????Vista SP2
When you say oyu cant turn on the wireless switch does that mean after flicking the switch usually located on the front or side of the laptop it sitll doesnt work. or have you tried holding the function key (fn) and hit the wireless symbol key on your keyboard it looks like the letter i with circles around itusually on the f8 key. by holding fn then f8 key it should turn it back on
May 07, 2011 | Toshiba Satellite A135-S4527 Notebook
I have a Toshiba Qosmio F60 series. My son using
We had the same problem and the above solution didn't work. It wasn't anything your son did, but obviously a problem with the computer itself. Disconnect from the mains and pull out the battery with the computer still going, then restart. When prompted just open Windows normally and the wifi was now functional again.
Jul 06, 2010 | Toshiba Computers & Internet
Acer 4720,when switched on wifi button,the light for wifi is flash and the funcion is worked.But switched off wifi button,the light is still on.How can i switch off the light?
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Jan 20, 2010 | Acer Aspire 4720 Notebook
Intel Pro 2100 Wireless LAN
i wish to take for my any think for acer aspire 7520 please
Apr 23, 2008 | Intel PRO/Wireless 2100 MiniPCI 802.11b
My wireless system on my laptop is off how can I turn it on? No wireless found in range! Make sure your wireless switch is on how can I put the switch on?
Some laptops have a switch in front next to the wireless light or on the side.
Some laptops use an F key (my toshiba is F8) so to turn on the wireless I would have to turn the switch on in front and then "toggle" the Wireless on by pressing the FN and the F8 keys.
Mar 26, 2008 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
