Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Refigirator is freezing my liquids on top shelf only
Model # GLRS267ZAB6
model type GSI-26
what could be the problem?
  • 220 Answers
If its anything like a GE refrigerator, there is a flapper valve between the freezer and refrigerator that controls the temp of the refrigerator compartment. There should be a plastic shroud at the top refrigerator compartment against the freezer wall. Remove it and see if the flapper is broken. Usually you can epoxy the flapper or if not, buy a new part.
Keep in mind my experience is with a GE, but I think its pretty much the same machine.
Posted on Feb 28, 2009
Milk freezing
Need more information, but try turning the fridge to normal and the freezer the same. Try placing those items in another location. Problem could be a bad air damper.
May 10, 2015 | Frigidaire FGHS2631PP Gallery 26 Cu. Ft....
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
Model TBX18KMB. Liquids on top shelf often freeze. Also,need to cut electric bills,can Power Saver help?
Turn the refrigerator temp control down try factory setting, usually c on frige and 3 on freezer control. The cold air circulating from the freezer enters at the top of the frige therefor it is usually colder.
Nov 04, 2009 | GE Refrigerators
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator is freezing my liquids on top shelf only
I think this was a double post. Hopefully I answered your other question.
Feb 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridgidaire refrigerator freezing
close the baffle that blows air onto the top shelf a bit.
Or you have a bad thermostat or thermistor- if it's a didital type temp cuicuit
Oct 25, 2007 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
230 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
