Question about Nintendo DS Console
Please help I went to far away in my house in a rainy day. I put my DS in my bag. I came back to house and i play my DS (lite) and i dropped (in the water). First Try Start Up is purple. Second Try I tryed to turn on again but shutdown. Last try i pulling the Turn on button. But it can't turn on but it can recharge battery.
  • 40 Answers
Open all the access doors and covers, take out the game, and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, or saltine crackers and put them in the ziplock bag also and put on top of your microwave oven or in the window where it gets direct sunlight. These items will help draw out all the moisture. I have done this many times on cell phones, gameboys, etc. and it works everytime.
Posted on Apr 25, 2009
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Tip
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
My daughter spilled water onto the touch screen of her two-day old DS Lite. The screen has obvious water in it and won't read the game card. Can't get it apart because no screwdriver will fit anything! ...
My DS Lite went through the wash one time. Luckily it didn't go through the whole cycle. It didn't work right away, for the next three days actually. But on the third day it did start working. I didn't have any calibration issues on the touch screen, thank god, but the L and R trigger buttons stopped working. Luckily, I only play Pok'emon, so it didn't hinder me too bad. But yeah, just give it time.
Dec 24, 2009 | Nintendo DS Lite Console
My ds lite keeps freezing because a drop of water went in it and i dont know what to do help!!!!!
DSl's hate water they die instantly!! Keep away from any liquids.
You will need a new motherboard at least to repair it, water damage is impossible to repair.
Dec 19, 2009 | Nintendo DS Lite Console
My Nintendo DS got wet, help?
My sister experienced the same thing - Somehow there was a melted ice pak over me and my sisters NDS so i read the Manual and it said if u move suddenly from a cold place to a warm/hot place water drops may form inside - so dont play or charge the NDS for a few days NOTICE! If it is fixed you may have to blow into it every time you play for aprox. a week
Mar 22, 2009 | Nintendo DS Lite Console
Wont turn on
do not throw it out call nintendo and see if they can fix it
Feb 25, 2009 | Nintendo DS Lite Console
R4 Version 3
the r4ds has a reset application when you press random buttons quickly and the r4 turns of sorry but i think you can turn it off by pressing the R BUTTON on the game loading screen... please pm me for any more help...
Feb 22, 2009 | Nintendo DS Lite Console
I have a Nintendo DS Lite that needs a new housing. It works fine, just the rounded hinge on the right is bent and cracked because it was dropped. Can a local repair shop put a new housing on, or do I...
Go to this page on Nintendo's website. Regardless of your warranty status, they will offer repair options.
"Nintendo DS Lite - Plastic Housing and Hinge Issues
If your Nintendo DS is experiencing issues with the plastic housing (such as a cracked hinge), please contact our Consumer Service Department at 1-800-255-3700 so that we may provide you with repair options."
Nov 30, 2008 | Nintendo Computers & Internet
Fixing my DS lite
don't panic you probably knocked the screens ribbon cable out you will need a special screw driver(ebay).there are many good guides available on taking them apart and putting them back toghether.the trick is to take your time and be very careful.
Jul 28, 2008 | Nintendo DS Console
Help
did u try charging it? or maybe put in a another game and try
May 31, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
