Question about Storkcraft Baby Aspen Stages Crib
Can not get side of crib to come down!
Help me lower the side rail!!!
  • Anonymous Mar 22, 2009
    I can't figure out how to drop this side either???
    Problem Solver:
  • 5 Answers
Pull up on the rail, then push with your shin on the bottom middle of the rail then it will slide down. If you watch the guides on the bottom you will see it slide back then it will slide down.
Posted on Apr 20, 2009
You pull up and push in with you knee on the lower part at the same time.
Posted on Mar 22, 2009
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
NO LONGER AVAILABLE
Be careful with used cribs as they can be quite dangerous.
I'm not sure if your idea will work,as both sides of the rail need to be raised up and down. Or do you mean that both sides of the crib go up and down?
If I had a picture it would help.lol
Make sure that if you can't fix the sliding rail that you leave it at the highest position so that baby can't pull itself up when he/she gets to that stage.
You could try finding another one(for parts) at a second-hand store,yardsale,etc.
Good luck.
Sep 23, 2009 | Storkcraft Baby Cynthia 04550 Crib
Squeaky bed crib rails
I had the same problem and I put baby oil on a rag and wiped the metal bars with it. I haven't had a problem since.
Jan 03, 2009 | Child Craft Baby Gear
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Plastic piece to lower side rial broke
If you have one side piece that works, I would like to buy it from you. Email bluewriter24@yahoo.com Thanks.
Jul 05, 2008 | Childesigns Bellmont Crib
The Dorel 3-1 convertible crib model # WM1633
Do not use this crib. This crib broke and caused my infant son of six months to get caught. He passed away on October 16th because of getting caught in this crib. I am trying to getting this crib recalled. Please Please do not use drop down cribs. They are entrappment devices for infants. 3 infants including my son have died in 2008 due to drop down side cribs. Please for your babies sake, take this crib back.
Jun 22, 2008 | Dorel Alexander
LOWER LEFT TRACK - FOR RAIL TO RAISE AND LOWER.
I have a Delta 5 in 1 Crib and I am having a hard time keeping the side rail up on the left side...... Pin doesn't seem to be working! How can I fix this very soon due to my second lil one on his way soon?????
Jun 06, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Lost parts
Go to www.afgbabyfurniture.com and you can order what you need. Mary
Mar 06, 2008 | AFG Daphne Crib
Kinderkraft crib
You just take the drop down side off and put the mattress at the lowest setting. We have the same crib and used it for a few months as a toddler bed.
Jan 11, 2008 | Kinderkraft Vermont Crib
Bassett crib sides falling down
You likely are missing the lower track assemblies. Part # CC (right) and DD (left). These screw into the lower inside legs on the side with the drop down rail to secure the rail from dropping off. See instructions, Step 1 and Step 2.
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
May 29, 2007 | Bassett Parson Ridge Crib
Storkcraft Baby Aspen Stages Crib Logo
171 people viewed this question
Top Storkcraft Baby Baby Gear Experts
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Storkcraft Baby Baby Gear Expert? Answer questions, earn points and help others
