My dell lcd tv (w2600) was working just fine for 2 years, then one day it just stop turning on. When I press the power button it makes the power up sound, but doesn't go on. Does anyone know how t fix it ??
-   I have had the exact same thing happen to me. I've owned the tv for three years and it has decided to stop working all together now. very p****d off! -   rossignol198
Same problem, this is my solution. The system will start everytime if starting from power off one starts from sleep. Thus the trick is to use sleep mode to shut it down. I do not use the sleep function on the remote (it would be worth a try, let me know if you do that), but rather I have chose VGA as the entry signal ad have hooked the TV to my PC, and then I put the PC in sleep mode. The TV will do the same. When it is in sleep mode through the PC, the system cvomes back to life if the remote from the cable is used to change channels.
the problem is with the capacitor inside the tv the power is not being transferred from the wall to...
(More)
the problem is with the capacitor inside the tv the power is not being transferred from the wall to the relay and to the capacitor and its too weak to power up the tv they need to be replaced and will cost up to 100 dollars to change them out the part itself is only about 7 dollars but has to be soldered into the board of the tv or something
