Question about LG Vu CU920 Cellular Phone
Ge to eNGLISH
IT WAS CHANGED TO sPANISH BY someone and I can't figure out how to change it back to eNGLISH I an't read the options since they are in Spamish Please help
  • 1 more comment
  • Kathleen Girgenti Feb 28, 2009
    I founnd the solution from my carrier's live chat. It took some time and you will be working blind since it is still in Spanish. Just follow the prompts that are giveneg. select the high light item on your phone, If you have changed the password already, thjat is the one they are asking for, not 0000
    All my contacts were still there too.
    Perform a Master Reset for the LG VU
    Goal:
    Fix:
    LG VU Keypad Layout
    Master Reset
    1. From the standby screen, tap the Menu icon.
    2. Tap Settings.
    3. Tap More.
    4. Tap Reset Settings.
    5. Tap Master Reset.
    6. "All settings reset to default value. Continue?" will appear, tap Yes.
    7. Enter Security code, tap OK.
      NOTE: The default security code is 0000.
    Master Clear
    2. Tap Settings.
    3. Tap More.
    5. Tap Master Clear.
    6. Scroll to and select desired option:
      • Handset
      • Memory Card
    7. "All settings reset to default value and all data will be deleted. Continue?" will appear, tap Yes.
    8. Enter Security code, tap OK.
    var solutionBaseUrl = '/answer-center/solutionDisplay.jsp?solutionId=';
    var transactionFragments = document.getElementsByName("transactionFragmentForm");
    var solutionLinks = document.getElementsByName("solutionLink");
    atgss_loadFragments(transactionFragments);
    atgss_modifySolutionLinks(solutionLinks);
    I solved it by going to
    Goal:
    Fix:
    LG VU Keypad Layout
    Master Reset
    2. Tap Settings.
    3. Tap More.
    Master Clear
    2. Tap Settings.
    3. Tap More.
      • Handset
      • Memory Card
    If you are viewing information on devices or services, please note: content reflects instructions for devices and services purchased from AT&T.
    Some differences may exist for devices not purchased from AT&T.
  • pjpffx May 11, 2010
    Press the Main Menu (looks like the 4 dice). Then press the settings button which is the last/bottom of four buttons on the right. Then press the Display button which is second from the top, on the left column. Five selections down is the "Languages" selection - change to either Automatic or English.
    Problem Solver:
  • 3 Answers
Go to your main menu and then go to the bottom when you can change you call settings and display settings click on the display settings then scroll down to the picture of the 2 A's and then either select automatic or english and then press set.
Posted on Sep 02, 2009
  • strawberr853 Sep 02, 2009
    oh for the display settings the picture is a computer screen
    Problem Solver:
  • 5 Answers
Go to the main menu, then go to the settings tab. Then go to Pantalla (display options), then go to Idomas, then choose your language you want. Hope this Helped
Posted on May 31, 2009
  • 107 Answers
Hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Posted on May 08, 2010
My computer had some loging in problems and when i took it to get fixed they changed the language from English to Spanish (where i live they speak spanish). I want it to go back to English but i cant...
You do the below seteps: This is what you do:
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages tab. If you see a drop down list of languages, see if it is set to English. If not, set to English. However, if you do not have this list there, you may need to install it.
May 21, 2011 | ASUS Eee 4G Notebook
When I changed the batteries, I am no longer able to get the display in English--it comes up in Spanish. There is no obvious button to change it. Thanks for your help.
The problem is not from the battery you changed. It should be from the sim card you changed. The phone's language is set to automatic, therefore it reads sim card languages automatically. To rectify this, since you do not understand spanish:
Option 1
-Put back the english sim then go to settings, and set your default language to English only
Option 2
-Send me your phone name and model so I can give you a reset code
THANKS. HOPE THIS HELPED.
Apr 23, 2011 | Cell Phones
MY PHONE CHANGED LANGUAGE FROM ENGLISH TO SPANISH...
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
May 21, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Accidently changed my language feature to spanish -can't figure out how to change it back to english-please help
Change the display language from English to Spanish or vice versa using the
Language menu.
1. From the main screen, press the Center Select key ( ).
2. Use the Navigation wheel to highlight Settings & Tools and press the
Center Select key ( ). (It's the last option)
3. Press Phone Settings, #5
4. Press Language, #4
5. Use the Navigation wheel to select English or Español, and press the
Oct 22, 2009 | Verizon Communications Samsung Juke Cell...
On screen language
found the manual online
Aug 02, 2008 | Sony DAV-DX255 System
GE Spacemaker Microwave model PVM 1870
Assuming you mean JVM1870 you can press the Options pad repeatedly until something about "Idioma" (language) appears, then press 1 for English.
You can download a free GE / Hotpoint owner's manual here.
Another first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. It may default to English.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 24, 2008 | Microwave Ovens
Language is in spanish
This works fine. I hold play and Skip both together. Now it Changed to English. Thanks
Apr 22, 2008 | Thomson GE Cordless Telephone 27995GE1
The Phone's mode is stuck on Spanish
Press and hold the "Skip" button. I did this while the answer machine was ON. The english voice will say that the language has changed to english.
Sep 30, 2007 | GE 27992GE5 Cordless Phone
Wrong language
In the menu one of the first options is language. If it is in spanish you may have to get someone that reads spanish to tell where this option in the menu is. Most new remote hand units have up and down and side to side arrows. Clicking the right side arrow usually will make selections, When you get to english if there is a select button or enter in the middle of the arrows, push that button if english is high-lighted or underlined or different color. Paul
Sep 23, 2007 | RCA E13319 13" TV
GE 25861GE3 Answering Systems Plays Back Messages in Spanish. How do I change it back to English?
The solution that Best Solution gave worked for me to change it back to English. Thanks bunches!
Aug 01, 2007 | GE 25861GE3 Twin Cordless Phone
LG Vu CU920 Cellular Phone Logo
277 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
