Question about Spectra KT2113 TV
My grand daughter owns a portable tv doesn't stay on
She turns on the tv and it tries to stay on but shuts off in a mater of seconds.It's a Spectra Model No.KT2113. What could be the problem?
    Genius:
  • 1,139 Answers
Hello fredpagan38,
This is an indication of a possible High Voltage problem, your set has what is called a shutdown circuit which detects excessive current which may cause X-Radiation to occur. The problems that may cause this are a short circuited Integrated High Voltage Transformer, a shorted circuited or open protection capacitor, or a defective Horizontal Output Transistor. To be sure you can buy the schematic and with a multimeter you can examine the voltages (power on) and resistances (power off and unplugged) of the components just mentioned. If you do not have a background in electronics, I would suggest that you have a TV repair technician look at the set and give you an estimate on it repair.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 28, 2009
Panasonic tv keeps turning off
Sounds like a power supply regulator board fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 02, 2014 | Panasonic Televison & Video
My sercurity system is shut down how do I reset it
I've owned a couple Grand Marquis, but never had this problem. Although, an Altima I once owned alarm was set-off and i didn't have the remote to turn if off. I learned you had to put the door key in the lock and turn it back and forth a couple times to shut it down. Maybe it will reset yours. Another vehicle you had to turn ignition key forward without starting the car, hold for 5-seconds turn off and then try staring. Not my best post
Mar 12, 2014 | 2000 Mercury Grand Marquis
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Tv will not stay on
If tv shuts off and turns back On itself than lamp is weak and need to be replaced.
If tv shuts off but does not turns On itself than you will see red light blinking on tv front, let me know how many times it blinks, there would be pause of 3 seconds in blinks so count pause to pause and post here to provide you helpful info about problem.
Thanks.
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
47in dlp tv that turns on then shuts back off
The lamp may be bad or a fan has stopped running. Remove your lamp and see if it's shattered or dark and gray in the center. Also your lamp timer could have reached it's limit. check your manual to see how you can reset the timer only if the lamp looks clear.
Jan 29, 2010 | Panasonic PT-47X54 47" Rear Projection...
Tv spectra model ce-6443 can't unlock
Press the DISP button and hold for 5 sec.
This should unlock your Spectra TV.
Jul 19, 2009 | Spectra Logic 5-CTV 5 in. Television
Turns on the shuts off
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
May 26, 2009 | Emerson DTE315 TV
My panasonic viera plasma tv is shutting off on its own
U WILL LAUGH, WHERE THE PLUG GOES INTO THE ACTUAL TV, NOT THE WALL, PUSH IT IN BETTER...I HAD EXACT PROBLEM AND CAME FROM 2 1/2 DAYS FROM GETTING NEW PLASMA!!! WHEEEW
Jan 27, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Aug 26, 2007 | Spectra SS213 TV
Tv shuts off after5 seconds
I,m sorry if not help you, but some those combo system when the Vcr have problem or stuck it shuts down, then you have to fix the Vcr frist. zcheck if the Vcr is ok. Aleixo
Aug 29, 2006 | eVision EC720E 20 in. TV/VCR/DVD Combo
Spectra KT2113 TV Logo
77 people viewed this question
Top Spectra Televison & Video Experts
echc93
Level 1 Expert
mikemail1
Tom Chichester
Are you a Spectra Televison and Video Expert? Answer questions, earn points and help others
