Question about O2 Xda Atom
Can't unlock well i switched off my phone while locked,but when i swithed it on it gives me the option of unlock,but the problem is that i can't use the touch screen ,so there is no way i can use the phone,what can i really do???? jeff.
Don't cry. Buy a new 'touch screen digitizer' from ebay and screw it in carefully. Google for directions on how to replace it. try 'xda-developers' for directions.About $15-20 a bargain. Sorted?
Barks
Posted on Mar 10, 2009
2001 Buick Regal. Power door lock swith will not lock doors.
Remove the door panel and unplug the connector to the door actuator. Probe the contacts with a voltmeter set on DC volts. Then operate the lock/unlock switch. You should see the voltage toggle from +12 volts to -12 volts. If you do, then the wiring, switch and connector are good and you have a bad actuator. Be prepared to start replacing all of them because they all operate the same number of cycles.
Jul 28, 2017 | 2003 Buick Regal
Just got a new phone and i inserted my sim card and its asking for a network lock
It's Network Unlock? Because Network Locked so it Network Unlock!!! You can specify the Network Current working and country,because that is Locked Network,if you Unlock it means you can any GSM Network Sim card in the Phone,if you not unlock means you can't use other Network Sim in the Phone,You can get the Unlock code from here Theunlockarena.com and Unlock it from Network LOCK,Follow the instructions below and unlock it step by step.
Samsung B5722 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung B5722 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung B5722 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung B5722 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung B5722 is locked to.
CODE: Its the unique Unlock Code for your Samsung B5722.
Aug 10, 2011 | Samsung B5722 Cell Phone
I need to unlock nokia c3 and its imei is 357884049648781 plz let me knw with this.....
f you wandered to unlock your Nokia c3 mobile follow these instructions, you first choose the make and model from their list along with the IMEI number and the network to which your Iphone phone is locked to. To find out the IMEI number, dial *#06# on your phone's keypad..Then select the payment option They accept most credit card like most of the unlock services, but the best part I found was the ability to pay by PayPal. PayPal gives me a secure payment option , follow these , then get the unlock code here in this site superunlockcodes using the unlock code specified in it unlock your mobile safely safely without vain ,
Aug 10, 2011 | Nokia 3110 Cellular Phone
My samsung sgh187 is locked
Your Phone locked to Network ? or security code? Network lock means use the Network Unlock code to unlock it....If it locked to security code means you can use the master reset code to reset the Phone...You can get the Unlock code from here Wickedunlock.com and Unlock it...You can follow the instructions below To enter the code in the Phone.. You can get the DEFAULT code from service provider and reset the Phone from security lock...
Samsung A187 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung A187 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung A187 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung A187 with a NOT ACCEPTED SIM Card.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung A187 is locked to.
CODE: Its the unique Unlock Code for your Samsung A187.
Aug 02, 2011 | Cell Phones
I have an samsung mobile. Model No E1310S. Please give me unlock code
http://unlock.nokiafree.org/ check it out and download the software and all you have to do is to follow the instruction... it may work on samsung mobiLe too...
or you may do this procedure: 1)the phone must not have it's sim card then switch it on swith it on and type #7465625*638*Code# = Disables Network lock here is your code is eight zeroz(00000000) 2) so it will be #7465625*638*00000000# but it will not Look Like that it wiLL be #7465625*638*--------# after it says Network lock disabLed then it is aLready ready for any sim cards
hope it may heLp.. din't forget to rate.. and thanks for using fixya.. cya my friend
Jul 15, 2010 | Cell Phones
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
Cant unlock keypad
wellcome try and send the imei no,the country lock to.
Jul 22, 2009 | Cell Phones
Unlock motorola v710 cell phone
MYSELF ALSO FACED THE SAME PROBLEM. SO I GOT THE UNLOCK CODE FROM UNLOCK CODE
NOW MY MOBILE IS WORKING GOOD.
Mar 28, 2009 | Motorola Mobility V710
Nokia 2630
go to seting and do factory restore option and then hold switch off swith and * and # together
and it will be done
Jun 30, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
T-mobile phone
just give me the phones serial number........send it to edwinsheringham@lycos.com and i will try and  give you the code for unlocking.
In newer phones:
#*7337#
this step sometimes also works
If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
tested on e-series phones - may work on similar models but not sure
please let me know the outcome
May 11, 2008 | Lands Phones
Computers & Internet Logo
74 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
