Question about Sony KV-32V16 TV
Sanyo dp3264 has sound but no picture
Power to tv is fine just no picture
Have lost picture with power outtage, sound still perfect, dvd's still play
Sounds like tuner fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 29, 2014 | Sanyo DP19648 19 in. LCD TV
I have a Sanyo DP42849 tv and the picture is real blurry almost seems like the picture is in slow motion but the sound is fine. When I shut the tv off it has a good picture for about 30 seconds then it's...
Try resetting, Not sure if this works for your model
Power off the TV, hold down the reset button on the remote and power up the tv with power button on tv while keeping reset depressed.
(Is there a restore factory setting or reset buried in the on screen menu? I couldn't find it in the manual, can you let us know if there is?)
here is the manual in case you don't have it
http://us.sanyo.com/dynamic/product/Downloads/DP42-46849-52449%20(331--)-15947801.pdf
May 15, 2014 | Televison & Video
My 42" Sanyo LCD TV which is 4 years old no longer
This is not a user repairable fault. Should be checked from its main power regulator board, and is a skilled work. Actually this is a repairable fault, but can do only by any technicain.
Jul 11, 2013 | Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
Televison & Video Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
