Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain and we cannot get the front panel off
    Genius:
  • 2,920 Answers
You have a clog in the pump and its in the bottom of the washer..probably a sock or wash cloth
Posted on Feb 28, 2009
Maytag maxima washer won't drain
get to the back of the unit and take out the 2 screws on the back of the lid . remove the lid. look at the front electrical panel -remove the screws holding it in place. look inside the unit on the right and left side -- there may be 2 screws holding the front on - about 7 inches down. there may be two screws also at the bottom of the front panel. If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all. If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions. If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Jan 08, 2014 | Maytag Washing Machines
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
I drained my drain hose on my samsung front washer still reading nd code and it sounds like the motor is trying to work
you will need to open the plug to the drain pump and make sure there is no obstruction that will be stopping the drain pump. if you remove the cover the drain pump there will still be water that comes out.
If there is no panel on the front so you can get at the drain pump you are going to have to remove the front panel of the washer to get to the drain pump.
The lid needs to be removed then the control panel and the rubber boot on the front panel lift the edge of the rubber boot and you will see the retainer clamp.
Mar 03, 2011 | Samsung WF337AA Front Load Washer
Washer is not draining. How do I remove the front panel of my Electrolux IQ front load washer (Model EIFLW55HIW) in order to access the drain pump? There is no access panel on the front of the washer....
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Feb 15, 2011 | Electrolux EIFLW55HIW Front Load Washer...
Drain wont drain on a epic washer where is the drain filter located at
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
Nov 14, 2010 | Maytag EPIC MFW9700S Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Washing machine has intermittent drain issues with F02 code
When the three screws are out of the bottom, you should be able to pull the front panel down (towards the floor) and then out from the bottom. Unscrew the big white cap on the drain housing. Be prepped for the water. Most of the time the problem is due to **** in there.
Sep 04, 2008 | Kenmore 4292x Front Load Washer
Water leak fromwasher during drain cykle
Removing the front panel:
1. Disconnect the washer from the electrical supply
and release the console.
2. Releasethe bellows fromthe front panel and remove
the (2) screws holding the door safety switch
assembly to the front panel.
3. On select models, disconnect the wires from the
light switch.
4. Raise the front of the washer and remove the (4)
screws securing the front panel to the washer base.
Feb 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
