Question about IBM ThinkPad 600E 2645 Notebook
Windows millennium startup menu
Same problem but i select the safe mode and nothing happen....
  • 530 Answers
Hi im josh in cebu phils. friend running safe mode means that your pc was not turn off properly in the previous work.thats why safe mode occur and it will come back to the original when it fully recovered the error. but when its not it means some files are missing and wre not recovered so thats the time you need to repair the softwre throug the installation cd and if it stills occur.you need to re install your O.S. thats all good luck hope i helped you.
Posted on Feb 28, 2009
I cannot get passed the Windows Error Recovery screen. If I select Launch Startup Repair nothing happens. If I select Start Windows Normally it goes to starting windows screen momentarily and returns to...
First try starting your computer in safe mode. Power down, then hit power button and tapping F8 will get you to this option window. You can also choose safe mode with networking. While in this mode check for any new updates. If you installed new software or hardware uninstall these. Try restarting computer. If this doesn't work and you have a recovery disk put it in while computer is on and then restart.
Apr 27, 2013 | Gateway NE56R10u Laptop
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
Startup menu will not start. It says windows is loading files but nothing is happening
try to start it in safe mode
power down, then during power on hit F8 awhile
run window in safe mode, then run the tools from windows
for clean up also defrag your harddisk if you know howto.
download ccleaner from ccleaner.com. clean up your system
regulary is moght help to speedup your system.
Mar 24, 2011 | HP Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Proxy host error BSOD on PH32DSP.dll
Many Windows 7 users are facing BSOD (Blue screen of Death) error.
Follow the below steps to resolve the error.
1. Startup in safe mode (tap the F8 key on your keyboard repeatedly as the computer is starting up)
2. Select a method of safe booting from the menu (first try with networking; if the crash still occurs, try without networking)
3. Once the system has booted, click the Start button and type MSCONFIG then press enter in Windows Vista (in Windows XP, click the Start button, then click “Run” and type MSCONFIG then press enter).
4. Go to the Startup tab.
5. Disable Kaspersky and any related items (e.g. kl1.sys), then press OK, then restart the system if it does not happen automatically. Startup normally (i.e. not in safe mode).
Alternatively you can launch the Kaspersky application and set it to not start at startup.
Aug 03, 2009 | Funk Software Computers & Internet
Windows protection error
boot it from your recovery disc or a proper bootable OS disk, and try repair mode. if this doesnt work, you will need to reinstall your OS
Mar 18, 2009 | HP Pavilion 6835 PC Desktop
Frozen Toshiba P100
Try This. Restart your computer and as soon as it boots up tap the F8 key repeatedly until you see windows advanced options menu. select safe mode. when it asks you for the operating system just hit enter. as soon as it boots to safe mode do this. click start> run> type msconfig then hit enter. On the system configuration utility click on the startup tab then select disable all. Click apply then close. restart your computer again. It may be a corrupted startup program that is preventing your computer to boot up properly.
Oct 08, 2008 | Toshiba Satellite L25-S119 Notebook
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Compaq Computer
when the pc is powering up, keep pressing F8 to get into safe mode, and when in the menu select last known good configuration and press enter for a reboot. This should get you running, if not restart again pressing F8, but this time select start windows in safe mode and whilst in safe mode select the administrator account and try doing a system restore to a date before you tried loading the programe, and let the pc re boot, and hopefully you are now ok.
Aug 15, 2007 | Matrox Millennium P750 (64 MB) Graphic...
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
