Question about Acer Aspire 3502WLCi Notebook
Memory upgrade for acer aspire 3502
When I ried to upgrade the memory from 2 X 256 to 2X1G using Kingston DDR333, PC2700 memory, it is not booting.
Help.
Thanks,
Iqbal
  • miqbal786 Mar 02, 2009
    Thanks for your help. It did not help. Once it booted and it showed only 448M not 1G. And after that I could not boot the system. Also, I tried to install the memory after I installed the new bios, I think, from the ACERSUPPORT site. No use. One thing I noticed that when the switched the 256 memory slot, it showed only 194M and when I reversed it shows 448M. Confusing and I am sure that tou know the reason for this.
    Thanks again and I appreciate ant help.
    MI
    President:
  • 2,653 Answers
Put back the old memory and update your bios to the latest version.
Then try again.
Let me know if you need any help doing this.
Posted on Feb 28, 2009
  • RescueTechLA
    RescueTechLA Mar 02, 2009
    It's showing less because your laptop uses it as "swap" memory for the video card. You can change the setting in the bios, usually anywhere from 8-128 (depending on your laptop).
    OH Wait, I get what you're saying now. Well if that's the case either the memory is damaged or the motherboard has some internal issues.
    Whenever I've encountered this problem in the past 90% of the time it was due to faults on the motherboard.
    If you know the memory is good, then it's safe to assume the motherboard is faulty.
  • 54 Answers
Try 1 memory at a time...Memory strips comes in pairs.
  • leprof969 Mar 03, 2009
    You have not the correct memory sticks for that computer (compatable), usally you can't just turn them around like that.
I HAVE AN 3003WLMi ACER LAPTOP, WITH 256 DDR AND 60 GB HARD DISK , HOW MUCH MORE DDR RAM CAN I EXPAND TO. THANKS
Here is what I found:
You can upgrade your Acer Aspire 3003WLMi upto a maximum of 2.0 GB, with maximum of 1GB per slot in 2 memory slots. The Acer Aspire 3003WLMi takes the PC2700 DDR SDRAM SODIMMs Memory Type.
From: http://www.buycomputermemory.com/memory/AcerAspire3003WLMiMemoryRAM.html
Dec 13, 2010 | Acer 3003WLMi Notebook
Toshiba model A70 which ram will spport to uprade max
You have 1 available upgradeable slot expandable to 1,536MB. Optional expansion memory: PC2700 (DDR 256MB/512MB/1024MB) SODIMM: Memory compatible with PC2700 DDR333
Apr 07, 2010 | Toshiba A70-S256 Notebook
I cannot find what type/speed or maximum memory that i can add to an acer Aspire ASE571 - ED450A desktop. Can you help
According to Acer support for the model Aspie E571 you can use the following:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM (dual-channel support on four DIMMs)
Feb 23, 2010 | Computers & Internet
RAM upgrade
Go to www.crucial.com and click on the Scan my System option. It will tell you how much memory your computer can handle, what is currently in the slots, and how much and what kind of memory is best for your system.
Feb 08, 2010 | Toshiba Satellite M45-S265 Notebook
I will like to upgrade my acer aspire 5002 wlci whit memory ram
Your Acer can accept up to 2GB (2 x 1GB) RAM chips.
PC2700 DDR333 SODIMM
Be careful with the static discharges that may occur. Be sure to be grounded properly.
Good luck
-Carlos:
Jan 08, 2010 | Acer Aspire 5002WLCi Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
HI I HAVE A TOSHIBA SATALLITE A55 SERIES. INTEL(R) CELERON(R) M PROCESSOR 1.50GHZ. I WOULD LIKE TO KNOW HOW MUCH MEMORY CAN I MAX IT TO, AND WICH MEMORY SHOULD I USE. PC2700 OR PC25300 OR DDR333
You can only max at 1GB. You should use the PC2700 DDR33 512MB memory to upgrade the system. Should cost you less than $25 for 2 of the standard power SODIMMs or $50 for 2 of the lower power SODIMMs.
Nov 10, 2009 | CMB T43 750 Notebook
Want to upgrade from 512ddram to at leat 1G. How would i know that my new purchase would be compatible with my set. I'm using a pentium d 820 on foxconn 865G7mf-sh motherboard. Tnx.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000166
That page has all the specs.
It says that you can use Dual Channel 400 / 333MHz DDR x2 DIMMs, Max 2GB
That can be bought at bestbuy for under 45 bux!
Kingston Technology Kingston ValueRAM - Memory - 1 GB - DIMM 184-pin - DDR - 333 MHz / PC2700 - 2.5 V KVR333/1GR $44.99
http://bestbuy.upgradebase.com/
Dec 16, 2008 | Computers & Internet
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
Ram memory upgrade
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
Acer Aspire 3502WLCi Notebook Logo
247 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
