Question about Apple MacBook PC Notebook
MAC BOOK SHUT OFF> CANNOT TURN ON.
When I go to turn it on, the on light flashes and there are beeping sounds.
I checked battery and it seems okay.
  • edteets Feb 28, 2009
    Apple MacBook PC Notebook. 3 short-3 long-3 short, I think.
    President:
  • 2,653 Answers
Which macbook do you have?
Can you describe the beeping pattern?
Posted on Feb 28, 2009
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    OK if you have one of the original macbooks then follow this guide here:
    GUIDE
    Choose the macbook that you have.
    Then on the following page click on MEMORY
    You need to remove the memory card(s) and reseat them.
    Make sure you use the CORRECT size screwdriver or else you'll strip the screws, it's really easy to do and it's a pain to fix it if you do afterwards. Trust me, I know. ;)
    Let me know if this works.
    If it doesn't you'll have to have an Apple Tech diagnose the problem.
    Best of luck!
  • RescueTechLA
    RescueTechLA Mar 02, 2009
    Did you try the steps I suggested yet?
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
The ups turns on, all the led light lit at the same time. what's the problem.
I believe you will find that your battery is either dead or shorted.
Aug 09, 2012 | Eaton Powerware® 5110 UPS System
Will not boot. seems the pc is activating but screen remains blank
It should beep once when you turn it on (unless it's a laptop). If it beeps a few times that's a trouble code that you can look up at the manufactures site. But, if it seems to be running okay, just no display: Maybe your monitor is dead/unplugged/shut-off. Try another monitor, if that fails, try another video card.
That is just generic troubleshooting, it could be something specific to the model. Start pulling parts out one at a time and see if it boots, my money is on your video card or monitor though.
In the future it helps us to know the model, when it stopped working, is it a PC or a laptop, what lights flash, etc.. More details better answers.
Feb 11, 2011 | HP Pavilion xh485 Notebook
Frozen Mac Book now with blank screen and 3 beeps
Pull your ram cards and restart... see what you get. Then restart WITH them... you may just have an unseated ram card.
Nov 17, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
May 29, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
Won't turn on
Did you try to disconnect the battery and connect you mac book to the charger? If it turns on with the power connected and without the battery, probably your battery is broken.
May 04, 2009 | Apple MacBook Mac Notebook
Beep will load is running
This sounds like the same problem I had. It turned out to be a loose solder joint on the potentiometer for the water level. A few minutes with a soldering iron and it was fixed. I'm not an appliance tech but as near as I can tell, any input from any button or knob will turn the machine on and/or create a beep. Therefore, a loose connection at various places on this board could cause the same problem. I have also read about a lot of control board problems with various kenmore appliances. I suspect many of them may have a similar cause. Hope this helps.
Mar 19, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
My g4 adapter light is orange when I plug it into the computer.
Hey, if this problem still exist for you... try this.
Hold down the power button and see if the computer responds.  If you hear a loud beep sound, that's good. Release the power button... The computer should come on.
Of course if that doesn't work.  Try checking to see if the battery has any charge by pressing the button on the bottom of the batter.  Use those light sensors to determine the charge level of the batter. If there is just one light flashing, the battery is not charged.  Give it some time to see if it changes.
You can also, just remove the battery, plug in the power cord again, and then try to power on the computer.
Let me know if any of this helps.(if its not too late)  = |
Anywho, have a great day!
enov8
Jan 15, 2009 | Apple PowerBook G4 Mac Notebook
Apple MacBook PC Notebook Logo
643 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
