Question about Price Pfister 048E0BC Catalina Double-Handle Centerset Lavatory Faucet with
Water is Coming out at top of supply line at valve assemble. I have pushed it up as far as it can go and clip is in. Some how I lost directions so I am not sure if there is something else I need to do.
  • 21 Answers
You need to check the  o ring and see if it is still there.  or if it has a cut in it.  take it off and shine a light down the supply see if you can see a black rubber ring inside that makes the ceal.  if it is cut or not in the right position than it will leak.  you might need new supply.
Posted on Jun 22, 2009
  • Cameron loker Jun 22, 2009
    you need to check the  o ring and see if it is still there.  or if it has a cut in it.  take it off and shine a light down the supply see if you can see a black rubber ring inside that makes the ceal.  if it is cut or not in the right position than it will leak.  you might need new supply.
How do I increase the water flow into the tank of a Verona toilet
1.) Check to make sure that the water shut-off valve is all the way open (the water valve a.k.a. the shut-off valve is located behind the toilet near the wall or the floor, depending upon installation placement.) The water supply line attaches to it and feeds up into the refill valve assembly inside the toilet tank.
2.) Check the float assembly or the refill valve assembly, make sure it hasn't bound up by getting caught on another part inside the tank.
3.) Check the water level to make sure that it sits about 1 inch below the overflow tube in the middle of the tank. If the water is lower, adjust the float inside the tank to raise the water level. For models that have a ball float, turn the screw on top of the fill valve clockwise to raise the water level. For models that contain a cylinder float valve attached to the fill valve, squeeze the clip on the side of the float and pull the float up until the water reaches the desired level.
Feb 17, 2015 | Home
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
How do I replace the water line going to the water valve assembly
That sounds favourite! Let me know how you get on. Is the tubing you have left long enough? And has it gone brittle? In which case it might be a good idea to replace it at the same time as the valve
May 20, 2012 | LG LFX25960 Bottom Freezer French Door...
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
My sunbean652sias says it has insufficient water pressure
Hello. The water coming into a dishwasher is from the hot water supply line nearby, often under the sink. Make sure that the valve on that dishwasher supply line is opened all the way. Turn it counter clockwise as far as it will go. If that does not solve your problem, consider replacing the dishwasher hot water supply line. The old line may be bent or partially clogged with sediment. J.
Jul 08, 2010 | Sunbeam Dishwashers
Model 110.81860110 will not run hot water
The hot water valve is not working or clogged. Disconnect the washer from the power supply to avoid electric shock. Turn off the water supply and remove the hot water fill hose from the hot water valve. Check the valve for lime scale clogging and clean it. Check the flow of hot water in the hot water fill hose by placing it in a bucket and opening the hot water supply valve. Reinstall the fill hose and turn on the water supply. Proceed below if the problem is not resolved.
Disconnect the washer from the power supply. Remove the screws from the front corners of the console then lift and flip the console to the back of the washer. Disconnect the lid switch wiring harness from the body of the machine by prying the connector lock and pulling it off.
The cabinet is held on to the back panel by two retaining clips. Insert the blade of a flat-bladed screwdriver into the lip of the clip then pry back to release it. Repeat this to the other clip.
Lift the lid and grab the front rim of the cabinet. Rock the cabinet towards you and lift it all the way. You now have access to the water inlet valve. Disconnect the wiring harness from the hot water valve terminals. Measure the resistance of the solenoid coil using an analog multimeter (set it to X1). Replace the entire valve assembly (part number 285805) if the multimeter reads it open.
Remove the fill hoses and the inlet hose from the valve assembly then remove the mounting screw. Install the new valve assembly and connect the fill hoses and inlet hose. Connect the wires to the proper valve solenoid terminals. The red connector goes to the hot water valve.
To reinstall the cabinet, line up the front bottom rail of the cabinet up and under the rail on the base of the washer. Place the cabinet back into position and put the retaining clips in the slots provided on the back panel then push it down into the slots on the cabinet. Reconnect the lid switch wiring harness and put the console back into place.
Feb 11, 2010 | Washing Machines
Tub completed cycle and wouldn't shut off the water
Is your machine a FAV6800A or FAV9800A? Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve. If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open Water Inlet Valve or a defective Pressure Switch. Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water drips into the bin after spin cycle
It sounds like the cold inlet valve is sticking.
The only solution would be to replace the inlet valve.
Jan 20, 2010 | Washing Machines
The fabric softner dispenser does not release the liquid softner
The fabric softener solenoid valve is faulty and must be replaced. It is sold as an assembly with the bleach solenoid valve with part number 997846. You need to remove the front panel to lift the top panel to inspect or replace the valves.
Front panel removal procedure:
  1. Unplug the machine.
  2. Turn off the water supply.
  3. Open the door and remove it by removing the screws on the hinges holding it.
  4. Remove the remaining two screws on the opposite side along the inside lip of the door opening.
  5. Press in on the outer upper edges of the front panel posts then twist it inward to release it from the clips on the face of the cabinet.
  6. Tilt the top of the front panel away from the washer and remove it.
  7. Remove the four screws holding the dispenser bezel to the top of the top panel.
  8. Remove the 5/16" hex head screws securing the two hold down brackets on the top panel.
  9. Swing the hold down brackets to the outside to unhook it from the slot in the top panel lip.
  10. Lift the front of the top panel and tilt it toward the rear of the machine.
  11. The dispenser valve assembly is the one on right of the water inlet valve assembly where the water supply line is attached to. The fabric softener dispenser valve is the one on the right most.
  12. Clean the terminals and the connector of the fabric softener dispenser valve.
  13. Grab a multimeter and check the resistance between its terminals. The resistance should be between 500 to 1000 ohms. If it reads open, replace the dispenser valve assembly.
  14. Remove the wire harness connections to the valve solenoids.
  15. Loosen and remove the hose clamps on the hoses.
  16. Loosen the valve mounting screws by turning it at least three full turns.
  17. Slide the valve assembly to the left and remove it from the bracket.
  18. Place a towel below the valve and remove the hoses.
  19. Install the new dispenser valve assembly in reverse order.
  20. Install the top panel, dispenser bezel, front panel and the door in reverse order of the removal procedure.
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Price Pfister 048E0BC Catalina Double-Handle Centerset Lavatory Faucet with Logo
94 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
