Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KV-36FS12 Lost Green
Blue and red colors work well.
Standby was flashing 4 times repeatedly. I replaced my horizontal line transformer and got my TV operating again. The standby timer light flashes 5 times repeatedly now.
It has good B/W with the color turned down so I'm pretty sure it's not CRT.
Self diagnosis service screen shows:
2: TB OCP N/A
3: TB OVP N/A
4: VSTOP 0
5:AKB 1
101: WDT 0
I've tested components on C board.(seem ok)
I've tried different cables and different video inputs.(no difference)
Diagnostic mode reset doesn't change redish picture.
I'd like to try adjusting the green color drive in the service menu.
I know how to get into the menu but how exactly do you do the adjusting once I'm in there?
TIA, TJ
    Brigadier General:
  • 8,619 Answers
Hi!
Five blinks means - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Posted on Feb 28, 2009
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Standby light flashing
go to sonny code on net will tell whats wrong
Jul 18, 2010 | Sony KV-36FS12 36" TV
Standby timer keeps flashing
HI,
Please count that how many times(count numbers) LED flashes in a specific time, and let me know, then i will be able to help you and can tell you the area of fault.
Hope you will understand my saying.
Thanks for using fixya.
Jul 23, 2009 | Sony KV-36FS12 36" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Feb 05, 2007 | Sony KV-32CS70 32" TV
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
400 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
